<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Design footing based on soil capacity. RAM SS Foundation Module.</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/248491/design-footing-based-on-soil-capacity-ram-ss-foundation-module</link><description>Hi, I&amp;#39;m using RAM SS for the spread footing design under gravity loads.
 RAM SS have an option to design the footing based on the full soil pressure.
 However, I only provided the allowable bearing pressure in RAM.
 How does RAM convert allowable bearing</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Design footing based on soil capacity. RAM SS Foundation Module.</title><link>https://communities.bentley.com/thread/776278?ContentTypeID=1</link><pubDate>Thu, 03 Aug 2023 16:25:34 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:77fec6b3-a9e5-4cf4-a95d-efc56dfd8b39</guid><dc:creator>Seth Guthrie</dc:creator><description>&lt;p&gt;I don&amp;#39;t usually recommend this approach. The&amp;nbsp;load factors are&amp;nbsp;calculated by taking the ratio of the factored and unfactored column axial force, this is similar for spread and pile cap foundations when this approach is used. Also note, the method is only used when the design loads include no moments.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
