Beam/Node Annotation differences
Greetings Every one,
While analyzing a Crane Beam model with offsets, i have noticed there is differences in beam Annotation values & the node annotation value of the same beam. For example see the below screen shot.
Node Annotation - we are checking Node Annotation for Node 7 & 8 of Beam no 6.
the node displacement values are 6.725 & 6.815 mm respectively & for
Beam Annotate - and when we switch to Beam Annotate for Beam no 6
the displacement values are 19.741 & 20.144 mm respectively.
I dont understand why there is a difference in these values. Technically they should be same.
combing both the criteria....
Did anyone face with similar problem and what's the solution for this??
