Moment and stress distribution along the length of PT beams in Ram Concept?
How can I get the moment and stress distribution along the length of PT beams in Ram Concept? All I can see are contour plots (2nd screenshot below) but is it possible to get the moment and stress distribution at intervals say every 1 ft along (similar to the 1st screenshot below) PT beams in Ram concept?
  • RAM Concept tabulates results like this for Load Combinations and Rule Set Designs for each cross section or design section in the model.
    For service stresses and moments at each cross section in a design strip, use Layers - Rule Set Designs - Service Design - Tables - Span Section Design. More detailed information for resultant forces and moments is also tabulated in Layers - Rule Set Designs - Service Design - Tables - Strip Forces.
