I would like to use Data Extraction to get the frame story shear for each story to input into an Excel sheet. However, in exported data file I could only see the frame shear at base and change in shear for the lower story. Is there any way or settings should I make to make the report having all story shear / changes in shear like the report showing on UI?
We don't have the other stories in the extracted data. Use a report, or an export of the report as text file, to get the full frame shear data for post-processing. It's already been requested, re: Enhancement 1072015
