<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>double bent plate with axial force.</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/249987/double-bent-plate-with-axial-force</link><description>In RAM connection software, when I include axial load for double bent plate connection, it does not check for prying.</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: double bent plate with axial force.</title><link>https://communities.bentley.com/thread/781721?ContentTypeID=1</link><pubDate>Wed, 13 Sep 2023 16:17:23 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:2c78e16f-7eb8-427f-a21d-b5fdd728f56b</guid><dc:creator>Seth Guthrie</dc:creator><description>&lt;p&gt;True, in the AISC bent plate (or double bent plate) connection template, only beam shear forces are considered. That&amp;#39;s a limitation.&lt;img style="max-height:240px;max-width:320px;" src="/resized-image/__size/640x480/__key/communityserver-discussions-components-files/5932/pastedimage1694621768610v1.png" alt=" " /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: double bent plate with axial force.</title><link>https://communities.bentley.com/thread/781504?ContentTypeID=1</link><pubDate>Tue, 12 Sep 2023 14:42:12 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:d04263c4-23e7-4509-82ac-c15961c0dd16</guid><dc:creator>Atul Malla</dc:creator><description>&lt;p&gt;My question/comment is when you have both vertical shear and axial force on a skewed beam, the bent plate bolted (to the support column) - welded to the beam web ignores the axial force and does not check bolt tension &amp;amp; prying at the bent plate to column interface.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: double bent plate with axial force.</title><link>https://communities.bentley.com/thread/781391?ContentTypeID=1</link><pubDate>Mon, 11 Sep 2023 21:24:27 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:2bba9c7d-2330-4df2-b280-b217162596bd</guid><dc:creator>Seth Guthrie</dc:creator><description>&lt;p&gt;What design code are you using? I assume the plates are bolted to the beam and that prying is considered when the loads are only shear forces.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
