Vertical Cross Bracing Failed.
I got two filed column, then I added cross bracing there, coulmn found passed but the brcaing is not passes, not with big section. Please check the issue. you can change the type of bracing, please make the bracing pass. If we can omit the bracing and make pass the column that attached with bracing is also okay.  ( I have add a beam in the mid of column as mid landing beam for stair, and there were bracing, 3 stairs and in 3 places i have done the same, is it okay? will it create any problem for construction?)  THANKS IN ADVANCED.
V8.-STaad02.09 Project_Full.std
Parents Reply Children
