Direct Analysis Method i STAAD PRO & Paramter FLEX
Hi;
My Question is the parameter FLEX should = 0.8 or 1.0 in STAAD PRO while define the direct analysis parameters. as i was reviewing the Discussions that arranged behind the same subject and i can find most of PPL is considered FLEX =1.0 and no comment from Bentley technical team on that. So can you confirm this parameter which value needs to consider.
