RAM Concept - Compression Reinforcement in Creep Time History Analysis
How does RAM Concept account for compression reinforcement when doing creep deflection calculations during a time history analysis? For reference, I'm using RAM Concept V8.4 and using ACI 209.2R-08 for the creep/shrinkage model.
Is Concept calculating the factor from Eq 3-10 in ACI 209.2R for each element? If so, how is Concept applying it?
All I could find in the manual was that compression steel is always considered but it's not clear how. Thanks!
