Dear Team,I am trying to import the line diagram from the DXF file which was created in Caddmate, I save the line diagram in the dxf 2000 version but this is not importing and giving me a fatal error during import.I tried saving the dxf file in multiple versions but this was also causing errors.I attached the dxf file could you please check and guide me with solutionPlease Guide Thanks 417-PF1.dxf
More information on this, some how the model got imported after trail runs, but it was incomplete .I have a curved members which are divided in to 3 Parts see the below image, I was expecting it to import similar like this.
But It imported something like this could you please check, and guide me in what went wrong?Also please guide me with the correct way of importing.Thanks and Regards
Curved lines cannot be imported via DXF into STAAD.Pro. Some more details on this topic can be found in this Wiki: DXF Drawing is not Imported Correctly into STAAD.Pro - RAM | STAAD | ADINA Wiki - RAM | STAAD | ADINA - Bentley Communities
Thank for your Response,What is the other way to model these curved beams in staad and do the correct analysis ?
You may model these curved members as a series of short straight segments. I think you should be able to import such geometry via DXF
