Hey,
I am having the following error and I can't figure out how to fix it.
*** ERROR : PROBLEM FACED IN READING LREFFILE - INTERNAL ERROR.
*** ERROR IN INPUT DATA FOR REFERENCE LOAD CASE 0 . ***
Please let me know if you see anything wrong with my model.
Ian
Centrifuge Sumps REV A.STD
There are many unnecessary UNIT commands in your Reference Loads data. Open STAAD Editor and carefully review all Reference Load data. Remove all UNIT commands which are not required. I.e., in the screenshot below UNIT commands in red are not required as UNIT commands in green are enough. There are many more such locations in the Reference Loads data. If you would fix this, the analysis should run fine.
Answer Verified By: Ian Suppo
That worked, thank you!
