Is it possible to create a General Section by defining polygon using OpenSTAAD
Staad provides the option to create a custom open section using a defined polygon (refer to the snapshot below). Sections created this way can be visualized as 3D objects when rendered instead of showing a simple line. Is there a way to create the same using OpenSTAAD. This helps in creating Built-up sections.
