RCDC VERSION 23.00.02.43 BEAM DESIGN ERROR WHEN DIFFERENT STEEL GRADES ARE USED.
Hello i have encountered this scenario if Steel Grade Main is Fe410 and Steel Grade is Fe250 ,the software does not design beam it gives an error as shown in the attachment.
but if steel grades are similar design is performed without an error.
iam attaching RCDC File for investigation.
Structure2-Beam-1-3.325 m.zip
