STAAD model correctly calculates base shear initially, but applies roughly 100 times this load for NRC 2010 static seismic
I'm using the built module for NRC 2010 seismic loads in STAAD. When reviewing the output, STAAD correctly calculates the base shear, but is applying many times this load to the structure. The calculated base shear of 76 kN is correct, but the applied loads of 4000 kN are much too high.
H366614_5200_Value Engineering.STD
