WHY TENSION ONLY MEMBERS ARE SEEING COMPRESSION ?
I have a model with x bracing and my angle sections are experiencing compression for repeat load cases which has dead and a lateral load combined? All other cases are showing tension only except for these cases? Also I have compression in those members along the full length (not like others have issues where its tension in one end and compression in other). Why is it happening?
I have uploaded the file via secure upload.
