Help! Unable to generate floor load.
I am trying to generate 2 floor load on roof with 2 different inclined plan.
Any one can help on this?Can staadpro 2007 do it?
The staad file is parked at the following links.
 Many Thanks!
 http://ifile.it/p836iqg
  • I am modeling flat slab as a column strip and bracing arrangement. I wish to apply floor loads on the column strips ( beam frame) and  ignoring loading of horizontal bracings.
    Is there a command in STAAD where we can instruct member to ignore load however account its stiffness in analysis.
    Thanks in advance
    Rgds
    Namit Gupta
  • Cant generate floor load ..
    STAAD SPACE
    START JOB INFORMATION
    ENGINEER DATE 19-Oct-09
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT FEET KIP
    JOINT COORDINATES
    1 0 44.875 0.00030009; 2 30 41.9531 0.00030009; 3 60 38.729 0.00030009;
    4 90 34.979 0.00030009; 5 120 34.401 0.00030009; 6 150 35 0.00030009;
    7 180 38.5729 0.00030009; 8 210 44.776 0.00030009; 9 240 52.765 0.00030009;
    10 270 61.5156 0.00030009; 11 300 69.8697 0.00030009;
    12 330 76.6197 0.00030009; 13 360 80.651 0.00030009; 14 390 81 0.00030009;
    16 0 25.8125 122; 17 30 25.6042 122; 18 60 25.5833 122; 19 90 25.7292 122;
    20 120 26 122; 21 150 26.3802 122; 22 180 26.869 122; 23 210 27.4948 122;
    24 240 28.265 122; 25 270 29.208 122; 26 300 30.328 122; 27 330 31.6563 122;
    28 360 33.208 122; 29 390 35 122; 31 450 39.671 122; 32 450 71.6302 0.00030009;
    42 90 0 44.5003; 43 150 0 44.5; 44 210 0 44.5; 45 270 0 44.5; 46 330 0 44.5;
    47 390 0 44.5; 48 450 0 44.5; 56 90 31.739 44.5003; 57 150 31.9807 44.5;
    58 210 38.7229 44.5; 59 270 50.1991 44.5; 60 330 60.8702 44.5;
    61 390 64.8874 44.5; 62 450 60.4358 44.5; 63 0 0 74.5; 65 30 0 74.5;
    67 60 0 74.5; 69 90 0 74.5; 71 120 0 74.5; 73 150 0 74.5; 75 180 0 74.5;
    77 210 0 74.5; 79 240 0 74.5; 81 270 0 74.5; 83 300 0 74.5; 85 330 0 74.5;
    87 360 0 74.5; 89 390 0 74.5; 93 450 0 74.5; 95 120 29.3455 74.5;
    96 180 31.5297 74.5; 97 240 38.0214 74.5; 98 300 46.0743 74.5;
    99 360 52.1007 74.5; 101 0 33.4036 74.5; 102 30 32.1146 74.5;
    103 60 30.8182 74.5; 104 90 29.4126 74.5; 105 150 29.8128 74.5;
    106 210 34.3765 74.5; 107 270 42.0735 74.5; 108 330 49.5616 74.5;
    109 390 53.3181 74.5; 110 450 52.3978 74.5; 111 0 0 122; 115 60 0 122;
    117 90 0 122; 121 150 0 122; 123 180 0 122; 127 240 0 122; 131 300 0 122;
    133 330 0 122; 137 390 0 122; 139 420 0 122; 140 30 0 44.5003;
    142 30 36.2264 44.5003; 143 420 77.4167 0.00030009; 144 420 37.088 122;
    179 210 43.7898 7.2503; 180 240 51.3302 7.2503; 181 270 59.6719 7.2503;
    182 300 67.554 7.2503; 183 330 74.0538 7.2503; 184 360 77.8726 7.2503;
    185 390 78.3749 7.2503; 186 420 75.0201 7.2503; 187 450 69.8064 7.2503;
    203 0 43.7586 7.2503; 204 30 41.0201 7.2503; 205 60 37.9592 7.2503;
    206 90 34.4511 7.2503; 207 120 33.909 7.2503; 208 150 34.5081 7.2503;
    212 180 37.8875 7.2503; 405 120 26.4789 115.2; 406 120 26.9579 108.4;
    407 120 27.4368 101.6; 408 120 27.9157 94.8; 409 120 28.3946 88;
    410 120 28.8736 81.2; 411 180 27.5362 115.2; 412 180 28.2035 108.4;
    413 180 28.8707 101.6; 414 180 29.5379 94.8; 415 180 30.2051 88;
    416 180 30.8723 81.2; 417 240 29.6617 115.2; 418 240 31.0584 108.4;
    419 240 32.4551 101.6; 420 240 33.8518 94.8; 421 240 35.2485 88;
    422 240 36.6452 81.2; 423 300 32.5822 115.2; 424 300 34.8364 108.4;
    425 300 37.0906 101.6; 426 300 39.3448 94.8; 427 300 41.599 88;
    428 300 43.8532 81.2; 429 360 35.9126 115.2; 430 360 38.6173 108.4;
    431 360 41.3219 101.6; 432 360 44.0266 94.8; 433 360 46.7312 88;
    434 360 49.4358 81.2; 435 0 26.8992 115.2; 436 0 27.9859 108.4;
    437 0 29.0727 101.6; 438 0 30.1594 94.8; 439 0 31.2461 88; 440 0 32.3328 81.2;
    441 30 26.5362 115.2; 442 30 27.4682 108.4; 443 30 28.4002 101.6;
    444 30 29.3323 94.8; 445 30 30.2643 88; 446 30 31.1963 81.2;
    447 60 26.3327 115.2; 448 60 27.0822 108.4; 449 60 27.8316 101.6;
    450 60 28.581 94.8; 451 60 29.3304 88; 452 60 30.0798 81.2;
    453 90 26.2565 115.2; 454 90 26.7838 108.4; 455 90 27.3111 101.6;
    456 90 27.8384 94.8; 457 90 28.3658 88; 458 90 28.8931 81.2;
    459 150 26.8716 115.2; 460 150 27.363 108.4; 461 150 27.8544 101.6;
    462 150 28.3458 94.8; 463 150 28.8372 88; 464 150 29.3286 81.2;
    465 210 28.48 115.2; 466 210 29.4651 108.4; 467 210 30.4503 101.6;
    468 210 31.4355 94.8; 469 210 32.4207 88; 470 210 33.4058 81.2;
    471 270 31.0498 115.2; 472 270 32.8916 108.4; 473 270 34.7334 101.6;
    474 270 36.5752 94.8; 475 270 38.417 88; 476 270 40.2588 81.2;
    477 330 34.2195 115.2; 478 330 36.7828 108.4; 479 330 39.3461 101.6;
    480 330 41.9094 94.8; 481 330 44.4727 88; 482 330 47.036 81.2;
    483 390 37.6224 115.2; 484 390 40.2448 108.4; 485 390 42.8671 101.6;
    486 390 45.4895 94.8; 487 390 48.1119 88; 488 390 50.7343 81.2;
    489 450 41.4929 115.2; 490 450 43.3149 108.4; 491 450 45.1368 101.6;
    492 450 46.9588 94.8; 493 450 48.7807 88; 494 450 50.6026 81.2;
    495 420 39.3358 115.2; 496 420 41.5837 108.4; 497 420 43.8315 101.6;
    498 420 46.0793 94.8; 499 420 48.3272 88; 500 420 50.575 81.2;
    501 5 25.7778 122; 502 10 25.7431 122; 503 15 25.7083 122; 504 20 25.6736 122;
    505 25 25.6389 122; 506 5 26.8387 115.2; 507 10 26.7782 115.2;
    508 15 26.7177 115.2; 509 20 26.6572 115.2; 510 25 26.5967 115.2;
    511 35 25.6007 122; 512 40 25.5972 122; 513 45 25.5938 122; 514 50 25.5903 122;
    515 55 25.5868 122; 516 65 25.6076 122; 517 70 25.6319 122; 518 75 25.6563 122;
    519 80 25.6806 122; 520 85 25.7049 122; 521 95 25.7743 122;
    522 100 25.8194 122; 523 105 25.8646 122; 524 110 25.9097 122;
    525 115 25.9549 122; 526 125 26.0634 122; 527 130 26.1267 122;
    528 135 26.1901 122; 529 140 26.2535 122; 530 145 26.3168 122;
    531 155 26.4617 122; 532 160 26.5431 122; 533 165 26.6246 122;
    534 170 26.7061 122; 535 175 26.7875 122; 536 185 26.9733 122;
    537 190 27.0776 122; 538 195 27.1819 122; 539 200 27.2862 122;
    540 205 27.3905 122; 541 215 27.6232 122; 542 220 27.7515 122;
    543 225 27.8799 122; 544 230 28.0083 122; 545 235 28.1366 122;
    546 245 28.4222 122; 547 250 28.5793 122; 548 255 28.7365 122;
    549 260 28.8937 122; 550 265 29.0508 122; 551 275 29.3947 122;
    552 280 29.5813 122; 553 285 29.768 122; 554 290 29.9547 122;
    555 295 30.1413 122; 556 305 30.5494 122; 557 310 30.7708 122;
    558 315 30.9921 122; 559 320 31.2135 122; 560 325 31.4349 122;
    561 335 31.9149 122; 562 340 32.1735 122; 563 345 32.4321 122;
    564 350 32.6908 122; 565 355 32.9494 122; 566 365 33.5067 122;
    567 370 33.8053 122; 568 375 34.104 122; 569 380 34.4027 122;
    570 385 34.7013 122; 571 395 35.348 122; 572 400 35.696 122;
    573 405 36.044 122; 574 410 36.392 122; 575 415 36.74 122; 576 425 37.5185 122;
    577 430 37.949 122; 578 435 38.3795 122; 579 440 38.81 122;
    580 445 39.2405 122; 581 395 37.908 115.2; 582 400 38.1935 115.2;
    583 405 38.4791 115.2; 584 410 38.7647 115.2; 585 415 39.0503 115.2;
    586 425 39.6954 115.2; 587 430 40.0549 115.2; 588 435 40.4144 115.2;
    589 440 40.7739 115.2; 590 445 41.1334 115.2; 591 365 36.1976 115.2;
    592 370 36.4826 115.2; 593 375 36.7675 115.2; 594 380 37.0525 115.2;
    595 385 37.3374 115.2; 596 335 34.5017 115.2; 597 340 34.7839 115.2;
    598 345 35.0661 115.2; 599 350 35.3483 115.2; 600 355 35.6305 115.2;
    601 305 32.8551 115.2; 602 310 33.128 115.2; 603 315 33.4009 115.2;
    604 320 33.6738 115.2; 605 325 33.9467 115.2; 606 275 31.3052 115.2;
    607 280 31.5606 115.2; 608 285 31.816 115.2; 609 290 32.0714 115.2;
    610 295 32.3268 115.2; 611 245 29.8931 115.2; 612 250 30.1244 115.2;
    613 255 30.3558 115.2; 614 260 30.5871 115.2; 615 265 30.8185 115.2;
    616 215 28.6769 115.2; 617 220 28.8739 115.2; 618 225 29.0708 115.2;
    619 230 29.2678 115.2; 620 235 29.4648 115.2; 621 185 27.6935 115.2;
    622 190 27.8508 115.2; 623 195 28.0081 115.2; 624 200 28.1654 115.2;
    625 205 28.3227 115.2; 626 155 26.9824 115.2; 627 160 27.0932 115.2;
    628 165 27.2039 115.2; 629 170 27.3147 115.2; 630 175 27.4255 115.2;
    631 125 26.5444 115.2; 632 130 26.6098 115.2; 633 135 26.6753 115.2;
    634 140 26.7407 115.2; 635 145 26.8062 115.2; 636 95 26.2936 115.2;
    637 100 26.3306 115.2; 638 105 26.3677 115.2; 639 110 26.4048 115.2;
    640 115 26.4419 115.2; 641 65 26.32 115.2; 642 70 26.3073 115.2;
    643 75 26.2946 115.2; 644 80 26.2819 115.2; 645 85 26.2692 115.2;
    646 35 26.5023 115.2; 647 40 26.4684 115.2; 648 45 26.4345 115.2;
    649 50 26.4006 115.2; 650 55 26.3667 115.2; 653 420 52.7898 74.5;
    686 210 42.8037 14.5; 687 240 49.8955 14.5; 688 270 57.8282 14.5;
    689 300 65.2385 14.5; 690 330 71.4879 14.5; 691 360 75.0943 14.5;
    692 390 75.7499 14.5; 693 420 72.6236 14.5; 694 450 67.9826 14.5;
    695 0 42.6423 14.5; 696 30 40.0871 14.5; 697 60 37.1893 14.5;
    698 90 33.9233 14.5; 699 120 33.4171 14.5; 700 150 34.0162 14.5;
    701 180 37.2021 14.5; 731 255 57.1403 0.00030009; 732 285 65.6926 0.00030009;
    733 315 73.2447 0.00030009; 734 345 78.6354 0.00030009;
    735 375 80.8255 0.00030009; 736 405 79.2083 0.00030009;
    737 435 74.5234 0.00030009; 822 255 31.9368 108.4; 823 255 33.5178 101.6;
    824 255 35.0989 94.8; 825 255 36.6799 88; 826 255 38.2609 81.2;
    827 285 41.8143 81.2; 828 285 39.8147 88; 829 285 37.815 94.8;
    830 285 35.8153 101.6; 831 285 33.8157 108.4; 832 315 35.7528 108.4;
    833 315 38.1047 101.6; 834 315 40.4566 94.8; 835 315 42.8085 88;
    836 315 45.1604 81.2; 837 345 37.6379 108.4; 838 345 40.2097 101.6;
    839 345 42.7815 94.8; 840 345 45.3533 88; 841 345 47.9251 81.2;
    842 375 39.3682 108.4; 843 375 41.9688 101.6; 844 375 44.5695 94.8;
    845 375 47.1701 88; 846 375 49.7708 81.2; 847 405 40.8833 108.4;
    848 405 43.2874 101.6; 849 405 45.6916 94.8; 850 405 48.0958 88;
    851 405 50.4999 81.2; 852 435 42.4278 108.4; 853 435 44.4412 101.6;
    854 435 46.4545 94.8; 855 435 48.4679 88; 856 435 50.4813 81.2;
    872 315 47.4777 74.5; 873 345 50.4591 74.5; 874 375 52.3332 74.5;
    875 405 52.8687 74.5; 876 435 52.4651 74.5; 877 285 43.7846 74.5;
    878 255 39.8187 74.5; 1018 90 30.5758 59.5; 1019 150 30.8967 59.5;
    1020 210 36.5497 59.5; 1021 270 46.1363 59.5; 1022 330 55.2159 59.5;
    1023 390 59.1027 59.5; 1024 450 56.4168 59.5; 1025 30 34.1706 59.5;
    1026 210 40.7633 29.5; 1027 240 40.9899 59.5; 1028 240 43.9585 44.5;
    1029 240 46.927 29.5; 1030 270 54.0137 29.5; 1031 300 50.8653 59.5;
    1032 300 55.6564 44.5; 1033 300 60.4474 29.5; 1034 330 66.1791 29.5;
    1035 360 57.8491 59.5; 1036 360 63.5975 44.5; 1037 360 69.3459 29.5;
    1038 390 70.3187 29.5; 1039 420 57.7482 59.5; 1040 420 62.7067 44.5;
    1041 420 67.6651 29.5; 1042 450 64.2092 29.5; 1043 0 35.7133 59.5;
    1044 0 38.023 44.5; 1045 0 40.3326 29.5; 1046 30 38.1568 29.5;
    1047 60 32.411 59.5; 1048 60 34.0038 44.5; 1049 60 35.5966 29.5;
    1050 90 32.8312 29.5; 1051 120 30.3634 59.5; 1052 120 31.3813 44.5;
    1053 120 32.3992 29.5; 1054 150 32.9985 29.5; 1055 180 32.9478 59.5;
    1056 180 34.3659 44.5; 1057 180 35.784 29.5; 1058 255 43.3063 59.5;
    1059 255 46.7939 44.5; 1060 255 50.2815 29.5; 1061 315 52.6657 59.5;
    1062 315 57.8537 44.5; 1063 315 63.0417 29.5; 1064 345 56.1322 59.5;
    1065 345 61.8053 44.5; 1066 345 67.4784 29.5; 1067 375 58.0699 59.5;
    1068 375 63.8066 44.5; 1069 375 69.5434 29.5; 1070 405 58.172 59.5;
    1071 405 63.4753 44.5; 1072 405 68.7786 29.5; 1073 435 56.9064 59.5;
    1074 435 61.3477 44.5; 1075 435 65.789 29.5; 1076 285 57.0177 29.5;
    1077 285 52.6067 44.5; 1078 285 48.1956 59.5; 1111 255 53.769 14.5;
    1112 255 55.4546 7.2503; 1113 315 68.2297 14.5; 1114 315 70.7372 7.2503;
    1115 345 73.1515 14.5; 1116 345 75.8934 7.2503; 1117 375 75.2801 14.5;
    1118 375 78.0527 7.2503; 1119 405 74.0819 14.5; 1120 405 76.6451 7.2503;
    1121 435 70.2303 14.5; 1122 435 72.3768 7.2503; 1123 285 63.5606 7.2503;
    1124 285 61.4287 14.5; 1172 285 45.9901 67; 1173 90 29.9942 67;
    1174 150 30.3548 67; 1175 210 35.4631 67; 1176 270 44.1049 67;
    1177 330 52.3887 67; 1178 390 56.2104 67; 1179 450 54.4073 67;
    1180 30 33.1426 67; 1181 240 39.5057 67; 1182 300 48.4698 67;
    1183 360 54.9749 67; 1184 420 55.269 67; 1185 0 34.5584 67; 1186 60 31.6146 67;
    1187 120 29.8544 67; 1188 180 32.2388 67; 1189 255 41.5625 67;
    1190 315 50.0717 67; 1191 345 53.2956 67; 1192 375 55.2015 67;
    1193 405 55.5204 67; 1194 435 54.6857 67; 1391 26.5 40.3852 14.5;
    1392 18.5 41.0666 14.5; 1393 11.5 41.6628 14.5; 1394 3.5 42.3442 14.5;
    1395 56.5 37.5274 14.5; 1396 48.5 38.3002 14.5; 1397 41.5 38.9763 14.5;
    1398 33.5 39.7491 14.5; 1399 86.5 34.3043 14.5; 1400 78.5 35.1753 14.5;
    1401 71.5 35.9374 14.5; 1402 63.5 36.8083 14.5; 1403 116.5 33.4761 14.5;
    1404 108.5 33.6111 14.5; 1405 101.5 33.7292 14.5; 1406 93.5 33.8642 14.5;
    1407 146.5 33.9463 14.5; 1408 138.5 33.7865 14.5; 1409 131.5 33.6467 14.5;
    1410 123.5 33.487 14.5; 1411 176.5 36.8304 14.5; 1412 168.5 35.9809 14.5;
    1413 161.5 35.2375 14.5; 1414 153.5 34.3879 14.5; 1415 26.5 38.4107 29.5;
    1416 18.5 38.9909 29.5; 1417 11.5 39.4986 29.5; 1418 3.5 40.0788 29.5;
    1419 3.5 37.8134 44.5; 1420 26.5 34.3505 59.5; 1421 18.5 34.7619 59.5;
    1422 11.5 35.1219 59.5; 1423 3.5 35.5333 59.5; 1424 56.5 35.8953 29.5;
    1425 48.5 36.578 29.5; 1426 41.5 37.1754 29.5; 1427 33.5 37.8581 29.5;
    1428 56.5 34.2631 44.5; 1429 56.5 32.6163 59.5; 1430 48.5 33.0855 59.5;
    1431 41.5 33.4961 59.5; 1432 33.5 33.9653 59.5; 1433 86.5 33.1538 29.5;
    1434 78.5 33.8912 29.5; 1435 71.5 34.5365 29.5; 1436 63.5 35.2739 29.5;
    1437 63.5 33.7395 44.5; 1438 86.5 30.7899 59.5; 1439 78.5 31.2793 59.5;
    1440 71.5 31.7075 59.5; 1441 63.5 32.1969 59.5; 1442 116.5 32.4496 29.5;
    1443 108.5 32.5648 29.5; 1444 101.5 32.6656 29.5; 1445 93.5 32.7808 29.5;
    1446 116.5 31.423 44.5; 1447 116.5 30.3881 59.5; 1448 108.5 30.4448 59.5;
    1449 101.5 30.4944 59.5; 1450 93.5 30.551 59.5; 1451 146.5 32.9285 29.5;
    1452 138.5 32.7687 29.5; 1453 131.5 32.6289 29.5; 1454 123.5 32.4691 29.5;
    1455 146.5 31.9108 44.5; 1456 138.5 31.7509 44.5; 1457 131.5 31.611 44.5;
    1458 123.5 31.4512 44.5; 1459 146.5 30.8345 59.5; 1460 138.5 30.6923 59.5;
    1461 131.5 30.5678 59.5; 1462 123.5 30.4256 59.5; 1463 176.5 35.459 29.5;
    1464 168.5 34.7162 29.5; 1465 161.5 34.0663 29.5; 1466 153.5 33.3234 29.5;
    1467 176.5 34.0877 44.5; 1468 168.5 33.4516 44.5; 1469 161.5 32.895 44.5;
    1470 153.5 32.259 44.5; 1471 176.5 32.7085 59.5; 1472 168.5 32.1616 59.5;
    1473 161.5 31.683 59.5; 1474 153.5 31.136 59.5; 1479 11.5 37.3343 44.5001;
    1502 48.5 34.8558 44.5001; 1503 108.5 31.5184 44.5001;
    1504 71.5 33.1356 44.5001; 1509 18.5 36.9151 44.5002;
    1514 41.5 35.3744 44.5002; 1519 33.5 35.9671 44.5003; 1520 26.5 36.436 44.5003;
    1527 93.5 31.6973 44.5003; 1528 86.5 32.0032 44.5003;
    1533 78.5 32.6072 44.5002; 1538 101.5 31.6019 44.5002;
    1539 41.5 36.2749 37.0001; 1540 48.5 35.7169 37.0001; 1541 90 31.1574 52.0002;
    1542 150 31.4387 52; 1543 30 35.1985 52.0002; 1544 0 41.4875 22;
    1545 30 39.122 22; 1546 60 36.3929 22; 1547 90 33.3772 22; 1548 120 32.9081 22;
    1549 150 33.5073 22; 1550 180 36.4931 22; 1551 0 36.8681 52; 1552 0 39.1778 37;
    1553 30 37.1916 37.0002; 1554 60 33.2074 52; 1555 60 34.8002 37;
    1556 90 32.2851 37.0002; 1557 120 30.8723 52; 1558 120 31.8902 37;
    1559 150 32.4896 37; 1560 180 33.6569 52; 1561 180 35.075 37;
    1562 3.5 41.2115 22; 1563 11.5 40.5807 22; 1564 18.5 40.0288 22;
    1565 26.5 39.3979 22; 1566 33.5 38.8036 22; 1567 41.5 38.0758 22;
    1568 48.5 37.4391 22; 1569 56.5 36.7113 22; 1570 63.5 36.0411 22;
    1571 71.5 35.2369 22; 1572 78.5 34.5333 22; 1573 86.5 33.7291 22;
    1574 93.5 33.3225 22; 1575 101.5 33.1974 22; 1576 108.5 33.0879 22;
    1577 116.5 32.9628 22; 1578 123.5 32.978 22; 1579 131.5 33.1378 22;
    1580 138.5 33.2776 22; 1581 146.5 33.4374 22; 1582 153.5 33.8557 22;
    1583 161.5 34.6519 22; 1584 168.5 35.3485 22; 1585 176.5 36.1447 22;
    1586 3.5 38.9461 37; 1587 11.5 38.4164 37.0001; 1588 18.5 37.953 37.0001;
    1589 26.5 37.4233 37.0001; 1590 33.5 36.9126 37.0001; 1591 56.5 35.0792 37;
    1592 63.5 34.5067 37; 1593 71.5 33.836 37.0001; 1594 78.5 33.2492 37.0001;
    1595 86.5 32.5785 37.0001; 1596 93.5 32.239 37.0001;
    1597 101.5 32.1337 37.0001; 1598 108.5 32.0416 37.0001; 1599 116.5 31.9363 37;
    1600 123.5 31.9601 37; 1601 131.5 32.12 37; 1602 138.5 32.2598 37;
    1603 146.5 32.4197 37; 1604 153.5 32.7912 37; 1605 161.5 33.4807 37;
    1606 168.5 34.0839 37; 1607 176.5 34.7734 37; 1608 3.5 36.6733 52;
    1609 11.5 36.2281 52.0001; 1610 18.5 35.8385 52.0001;
    1611 26.5 35.3933 52.0001; 1612 33.5 34.9662 52.0001;
    1613 41.5 34.4352 52.0001; 1614 48.5 33.9706 52.0001; 1615 56.5 33.4397 52;
    1616 63.5 32.9682 52; 1617 71.5 32.4216 52.0001; 1618 78.5 31.9432 52.0001;
    1619 86.5 31.3966 52.0001; 1620 93.5 31.1242 52.0001;
    1621 101.5 31.0481 52.0001; 1622 108.5 30.9816 52.0001; 1623 116.5 30.9056 52;
    1624 123.5 30.9384 52; 1625 131.5 31.0894 52; 1626 138.5 31.2216 52;
    1627 146.5 31.3727 52; 1628 153.5 31.6975 52; 1629 161.5 32.289 52;
    1630 168.5 32.8066 52; 1631 176.5 33.3981 52; 1702 208.5 40.5143 29.5;
    1703 197.5 38.6886 29.5; 1704 192.5 37.8587 29.5; 1705 181.5 36.033 29.5;
    1706 208.5 38.505 44.5; 1707 197.5 36.9075 44.5; 1708 192.5 36.1813 44.5;
    1709 181.5 34.5838 44.5; 1710 208.5 36.3696 59.5; 1711 197.5 35.0489 59.5;
    1712 192.5 34.4486 59.5; 1713 181.5 33.1279 59.5; 1714 227.5 44.3588 29.5;
    1715 222.5 43.3315 29.5; 1716 211.5 41.0714 29.5; 1717 227.5 41.777 44.5;
    1718 222.5 40.9044 44.5; 1719 211.5 38.9846 44.5; 1720 227.5 39.1398 59.5;
    1721 222.5 38.3998 59.5; 1722 211.5 36.7717 59.5; 1731 238.5 49.5409 14.5;
    1732 238.5 46.6188 29.5; 1733 238.5 43.6967 44.5; 1734 238.5 40.7679 59.5;
    1751 208.5 42.5236 14.5; 1752 197.5 40.4697 14.5; 1753 192.5 39.5361 14.5;
    1754 181.5 37.4822 14.5; 1755 227.5 46.9406 14.5; 1756 222.5 45.7586 14.5;
    1757 211.5 43.1583 14.5; 1758 210 41.7835 22; 1759 240 48.4112 22;
    1760 210 39.7431 37; 1761 240 42.4742 52; 1762 240 45.4427 37;
    1763 181.5 33.8559 52; 1764 192.5 35.315 52; 1765 197.5 35.9782 52;
    1766 208.5 37.4373 52; 1767 211.5 37.8782 52; 1768 222.5 39.6521 52;
    1769 227.5 40.4584 52; 1770 227.5 43.0679 37; 1771 222.5 42.1179 37;
    1772 211.5 40.028 37; 1773 181.5 35.3084 37; 1774 192.5 37.02 37;
    1775 197.5 37.798 37; 1776 208.5 39.5097 37; 1777 238.5 48.0798 22;
    1778 238.5 45.1577 37; 1779 238.5 42.2323 52; 1780 181.5 36.7576 22;
    1781 192.5 38.6974 22; 1782 197.5 39.5791 22; 1783 208.5 41.5189 22;
    1784 211.5 42.1149 22; 1785 222.5 44.545 22; 1786 227.5 45.6497 22;
    1787 210 37.6363 52; 1828 253 49.8342 29.5; 1829 242 47.3742 29.5;
    1830 253 46.4158 44.5; 1831 242 44.3365 44.5; 1832 253 42.9975 59.5;
    1833 242 41.2988 59.5; 1834 268 53.516 29.5; 1835 257 50.7791 29.5;
    1836 268 49.7451 44.5; 1837 257 47.2479 44.5; 1838 268 45.759 59.5;
    1839 257 43.6836 59.5; 1840 253 53.2526 14.5; 1841 242 50.412 14.5;
    1842 268 57.287 14.5; 1843 257 54.3103 14.5; 1892 283 47.9211 59.5;
    1893 272 46.4109 59.5; 1894 283 52.2857 44.5; 1895 272 50.5201 44.5;
    1896 283 56.6172 29.5; 1897 272 54.4142 29.5; 1898 298 59.9901 29.5;
    1899 287 57.475 29.5; 1900 298 55.2497 44.5; 1901 287 53.0133 44.5;
    1902 298 50.5094 59.5; 1903 287 48.5516 59.5; 1904 313 62.6958 29.5;
    1905 302 60.7933 29.5; 1906 313 57.5607 44.5; 1907 302 55.9493 44.5;
    1908 313 52.4256 59.5; 1909 302 51.1054 59.5; 1910 283 60.9487 14.5;
    1911 272 58.3083 14.5; 1912 298 64.7305 14.5; 1913 287 61.9367 14.5;
    1914 313 67.8309 14.5; 1915 302 65.6373 14.5; 2068 328 65.7607 29.5;
    2069 317 63.46 29.5; 2070 328 60.468 44.5; 2071 317 58.2559 44.5;
    2072 328 54.8759 59.5; 2073 317 53.0057 59.5; 2074 343 61.6806 44.5;
    2075 332 60.9949 44.5; 2076 343 67.3051 29.5; 2077 332 66.3523 29.5;
    2078 343 56.01 59.5; 2079 332 55.3381 59.5; 2080 358 69.0969 29.5;
    2081 347 67.7274 29.5; 2082 358 63.3586 44.5; 2083 347 62.0442 44.5;
    2084 358 57.6202 59.5; 2085 347 56.3611 59.5; 2086 373 69.517 29.5;
    2087 362 69.3722 29.5; 2088 373 63.7788 44.5; 2089 362 63.6254 44.5;
    2090 373 58.0405 59.5; 2091 362 57.8786 59.5; 2092 388 70.2153 29.5;
    2093 377 69.6467 29.5; 2094 388 64.7433 44.5; 2095 377 63.9507 44.5;
    2096 388 58.965 59.5; 2097 377 58.2076 59.5; 2098 403 68.984 29.5;
    2099 392 70.1133 29.5; 2100 403 63.6636 44.5; 2101 392 64.6991 44.5;
    2102 403 58.2961 59.5; 2103 392 58.9786 59.5; 2104 418 67.8136 29.5;
    2105 407 68.6302 29.5; 2106 418 62.8092 44.5; 2107 407 63.3728 44.5;
    2108 418 57.8047 59.5; 2109 407 58.1155 59.5; 2110 433 66.0391 29.5;
    2111 422 67.415 29.5; 2112 433 61.5289 44.5; 2113 422 62.5255 44.5;
    2114 433 57.0186 59.5; 2115 422 57.636 59.5; 2116 448 64.4198 29.5;
    2117 437 65.5783 29.5; 2118 448 60.5573 44.5; 2119 437 61.2261 44.5;
    2120 448 56.4821 59.5; 2121 437 56.8411 59.5; 2122 328 71.0535 14.5;
    2123 317 68.6642 14.5; 2124 343 72.9297 14.5; 2125 332 71.7097 14.5;
    2126 358 74.8353 14.5; 2127 347 73.4105 14.5; 2128 373 75.2553 14.5;
    2129 362 75.1191 14.5; 2130 388 75.6873 14.5; 2131 377 75.3427 14.5;
    2132 403 74.3043 14.5; 2133 392 75.5275 14.5; 2134 418 72.818 14.5;
    2135 407 73.8875 14.5; 2136 433 70.5494 14.5; 2137 422 72.3045 14.5;
    2138 448 68.2823 14.5; 2139 437 69.9306 14.5; 2140 270 48.1677 52;
    2141 330 58.043 52; 2142 390 61.9951 52; 2143 450 58.4263 52;
    2144 270 55.921 22; 2145 300 62.8429 22; 2146 330 68.8335 22;
    2147 360 72.2201 22; 2148 390 73.0343 22; 2149 420 70.1444 22;
    2150 450 66.0959 22; 2151 270 52.1064 37; 2152 300 53.2608 52;
    2153 300 58.0519 37; 2154 330 63.5246 37; 2155 360 60.7233 52;
    2156 360 66.4717 37; 2157 390 67.603 37; 2158 420 60.2275 52;
    2159 420 65.1859 37; 2160 450 62.3225 37; 2161 255 45.0501 52;
    2162 255 48.5377 37; 2163 315 55.2597 52; 2164 315 60.4477 37;
    2165 345 58.9687 52; 2166 345 64.6418 37; 2167 375 60.9383 52;
    2168 375 66.675 37; 2169 405 60.8237 52; 2170 405 66.127 37;
    2171 435 59.127 52; 2172 435 63.5683 37; 2173 285 59.2232 22;
    2174 285 54.8122 37; 2175 285 50.4012 52; 2176 255 52.0253 22;
    2177 315 65.6357 22; 2178 345 70.3149 22; 2179 375 72.4117 22;
    2180 405 71.4303 22; 2181 435 68.0096 22; 2182 242 48.8931 22;
    2183 253 51.5434 22; 2184 242 45.8554 37; 2185 253 48.125 37;
    2186 242 42.8176 52; 2187 253 44.7066 52; 2188 257 45.4658 52;
    2189 257 52.5447 22; 2190 257 49.0135 37; 2191 268 55.4015 22;
    2192 268 51.6306 37; 2193 268 47.752 52; 2194 272 56.3613 22;
    2195 272 52.4672 37; 2196 272 48.4655 52; 2197 283 50.1034 52;
    2198 283 54.4514 37; 2199 283 58.7829 22; 2200 287 59.7059 22;
    2201 298 62.3603 22; 2202 287 55.2442 37; 2203 298 57.6199 37;
    2204 287 50.7824 52; 2205 298 52.8795 52; 2206 302 63.2153 22;
    2207 313 65.2634 22; 2208 302 58.3713 37; 2209 313 60.1283 37;
    2210 302 53.5274 52; 2211 313 54.9932 52; 2212 317 66.0621 22;
    2213 328 68.4071 22; 2214 317 60.858 37; 2215 328 63.1144 37;
    2216 317 55.6308 52; 2217 328 57.6719 52; 2218 332 69.031 22;
    2219 332 63.6736 37; 2220 332 58.1665 52; 2221 343 58.8453 52;
    2222 343 64.4929 37; 2223 343 70.1174 22; 2224 347 70.569 22;
    2225 358 71.9661 22; 2226 347 64.8858 37; 2227 358 66.2277 37;
    2228 347 59.2027 52; 2229 358 60.4894 52; 2230 362 60.752 52;
    2231 362 66.4988 37; 2232 362 72.2457 22; 2233 373 72.3862 22;
    2234 373 66.6479 37; 2235 373 60.9096 52; 2236 377 72.4947 22;
    2237 377 66.7987 37; 2238 377 61.0792 52; 2239 388 61.8542 52;
    2240 388 67.4793 37; 2241 388 72.9513 22; 2242 392 72.8204 22;
    2243 392 67.4062 37; 2244 392 61.8389 52; 2245 403 71.6441 22;
    2246 403 66.3238 37; 2247 403 60.9799 52; 2248 407 71.2588 22;
    2249 407 66.0015 37; 2250 407 60.7442 52; 2251 418 70.3158 22;
    2252 418 65.3114 37; 2253 418 60.307 52; 2254 422 69.8597 22;
    2255 422 64.9702 37; 2256 422 60.0807 52; 2257 433 68.2943 22;
    2258 433 63.784 37; 2259 433 59.2738 52; 2260 437 67.7545 22;
    2261 437 63.4022 37; 2262 437 59.0336 52; 2263 448 66.3511 22;
    2264 448 62.4886 37; 2265 448 58.5197 52; 2630 242 50.0069 16.5;
    2631 253 52.7968 16.5; 2632 242 46.9692 31.5; 2633 253 49.3784 31.5;
    2634 242 43.9315 46.5; 2635 253 43.4532 57.5; 2636 257 44.1589 57.5;
    2637 257 53.8394 16.5; 2638 257 50.3083 31.5; 2639 268 56.7842 16.5;
    2640 268 53.0132 31.5; 2641 268 49.2136 46.5; 2642 272 57.7891 16.5;
    2643 272 53.895 31.5; 2644 272 49.9722 46.5; 2645 283 51.7037 46.5;
    2646 283 56.0396 31.5; 2647 283 60.3711 16.5; 2648 287 61.3418 16.5;
    2649 298 64.0984 16.5; 2650 287 56.8801 31.5; 2651 298 59.3581 31.5;
    2652 287 52.4184 46.5; 2653 298 54.6177 46.5; 2654 302 64.9914 16.5;
    2655 313 67.1462 16.5; 2656 302 60.1475 31.5; 2657 313 62.0111 31.5;
    2658 302 55.3035 46.5; 2659 313 56.876 46.5; 2660 317 67.9703 16.5;
    2661 328 70.3478 16.5; 2662 317 62.7661 31.5; 2663 328 65.055 31.5;
    2664 317 57.5559 46.5; 2665 328 59.7224 46.5; 2666 332 70.9954 16.5;
    2667 332 65.638 31.5; 2668 332 60.2406 46.5; 2669 343 60.9245 46.5;
    2670 343 66.5552 31.5; 2671 343 72.1797 16.5; 2672 347 72.6528 16.5;
    2673 358 74.0702 16.5; 2674 347 66.9696 31.5; 2675 358 68.3318 31.5;
    2676 347 61.2865 46.5; 2677 358 62.5934 46.5; 2678 362 58.6448 57.5;
    2679 362 68.606 31.5; 2680 362 74.3528 16.5; 2681 373 74.4902 16.5;
    2682 373 68.7519 31.5; 2683 373 63.0137 46.5; 2684 377 74.5833 16.5;
    2685 377 68.8873 31.5; 2686 377 63.185 46.5; 2687 388 63.9729 46.5;
    2688 388 69.4857 31.5; 2689 388 74.9577 16.5; 2690 392 74.8056 16.5;
    2691 392 69.3914 31.5; 2692 392 63.9364 46.5; 2693 403 73.5949 16.5;
    2694 403 68.2746 31.5; 2695 403 62.9479 46.5; 2696 407 73.1865 16.5;
    2697 407 67.9292 31.5; 2698 407 62.6719 46.5; 2699 418 72.1508 16.5;
    2700 418 67.1463 31.5; 2701 418 62.1419 46.5; 2702 422 71.6526 16.5;
    2703 422 66.7631 31.5; 2704 422 61.8736 46.5; 2705 433 69.948 16.5;
    2706 433 65.4378 31.5; 2707 433 60.9275 46.5; 2708 437 69.3503 16.5;
    2709 437 64.998 31.5; 2710 437 60.6414 46.5; 2711 448 67.7673 16.5;
    2712 448 63.9048 31.5; 2713 448 60.014 46.5; 2714 242 47.7793 27.5;
    2715 253 50.29 27.5; 2716 242 44.7415 42.5; 2717 253 46.8716 42.5;
    2718 242 41.7038 57.5; 2719 253 45.96 46.5; 2720 257 46.7727 46.5;
    2721 257 51.2499 27.5; 2722 257 47.7187 42.5; 2723 268 54.0188 27.5;
    2724 268 50.2479 42.5; 2725 268 46.2905 57.5; 2726 272 54.9334 27.5;
    2727 272 51.0393 42.5; 2728 272 46.9588 57.5; 2729 283 48.503 57.5;
    2730 283 52.8632 42.5; 2731 283 57.1947 27.5; 2732 287 58.0699 27.5;
    2733 298 60.6222 27.5; 2734 287 53.6082 42.5; 2735 298 55.8818 42.5;
    2736 287 49.1465 57.5; 2737 298 51.1414 57.5; 2738 302 61.4392 27.5;
    2739 313 63.3805 27.5; 2740 302 56.5952 42.5; 2741 313 58.2454 42.5;
    2742 302 51.7512 57.5; 2743 313 53.1103 57.5; 2744 317 64.1539 27.5;
    2745 328 66.4664 27.5; 2746 317 58.9498 42.5; 2747 328 61.1737 42.5;
    2748 317 53.7057 57.5; 2749 328 55.6215 57.5; 2750 332 67.0666 27.5;
    2751 332 61.7092 42.5; 2752 332 56.0923 57.5; 2753 343 56.7661 57.5;
    2754 343 62.4305 42.5; 2755 343 68.0551 27.5; 2756 347 68.4851 27.5;
    2757 358 69.862 27.5; 2758 347 62.802 42.5; 2759 358 64.1237 42.5;
    2760 347 57.1189 57.5; 2761 358 58.3853 57.5; 2762 362 62.8592 46.5;
    2763 362 64.3916 42.5; 2764 362 70.1385 27.5; 2765 373 70.2822 27.5;
    2766 373 64.5439 42.5; 2767 373 58.8056 57.5; 2768 377 70.4062 27.5;
    2769 377 64.7102 42.5; 2770 377 58.9734 57.5; 2771 388 59.7355 57.5;
    2772 388 65.4729 42.5; 2773 388 70.9449 27.5; 2774 392 70.8352 27.5;
    2775 392 65.421 42.5; 2776 392 59.7414 57.5; 2777 403 69.6933 27.5;
    2778 403 64.373 42.5; 2779 403 59.0118 57.5; 2780 407 69.3311 27.5;
    2781 407 64.0738 42.5; 2782 407 58.8165 57.5; 2783 418 68.4809 27.5;
    2784 418 63.4764 42.5; 2785 418 58.472 57.5; 2786 422 68.0669 27.5;
    2787 422 63.1774 42.5; 2788 422 58.2879 57.5; 2789 433 66.6405 27.5;
    2790 433 62.1302 42.5; 2791 433 57.62 57.5; 2792 437 66.1586 27.5;
    2793 437 61.8064 42.5; 2794 437 57.4258 57.5; 2795 448 64.9348 27.5;
    2796 448 61.0723 42.5; 2797 448 57.0254 57.5; 3102 3.5 40.6829 25.5;
    3103 11.5 40.0757 25.5; 3104 18.5 39.5444 25.5; 3105 26.5 38.9372 25.5;
    3106 33.5 38.3624 25.5; 3107 41.5 37.6556 25.5; 3108 48.5 37.0372 25.5;
    3109 56.5 36.3305 25.5; 3110 63.5 35.6831 25.5; 3111 71.5 35.5638 18.5;
    3112 78.5 34.8329 18.5; 3113 86.5 33.9975 18.5; 3114 93.5 33.5753 18.5;
    3115 101.5 33.4456 18.5; 3116 108.5 33.3321 18.5; 3117 116.5 33.2024 18.5;
    3118 123.5 33.2155 18.5; 3119 131.5 33.3753 18.5; 3120 138.5 33.5151 18.5;
    3121 146.5 33.6749 18.5; 3122 153.5 34.104 18.5; 3123 161.5 34.9251 18.5;
    3124 168.5 35.6436 18.5; 3125 176.5 36.4647 18.5; 3126 3.5 39.4747 33.5;
    3127 11.5 38.9214 33.5; 3128 18.5 38.4373 33.5; 3129 26.5 37.8841 33.5;
    3130 33.5 37.3539 33.5; 3131 41.5 36.6951 33.5; 3132 48.5 36.1187 33.5;
    3133 56.5 35.46 33.5; 3134 63.5 34.8648 33.5; 3135 71.5 34.1629 33.5;
    3136 78.5 33.5488 33.5; 3137 86.5 32.847 33.5; 3138 93.5 32.4918 33.5;
    3139 101.5 32.3819 33.5; 3140 108.5 32.2857 33.5; 3141 116.5 32.1758 33.5;
    3142 123.5 32.1976 33.5; 3143 131.5 32.3575 33.5; 3144 138.5 32.4973 33.5;
    3145 146.5 32.6571 33.5; 3146 153.5 33.0396 33.5; 3147 161.5 33.7539 33.5;
    3148 168.5 34.379 33.5; 3149 176.5 35.0933 33.5; 3150 3.5 37.2053 48.5;
    3151 11.5 36.7443 48.5; 3152 18.5 36.3409 48.5; 3153 26.5 35.8799 48.5;
    3154 33.5 35.4333 48.5; 3155 41.5 34.8735 48.5; 3156 48.5 34.3837 48.5;
    3157 56.5 33.8239 48.5; 3158 63.5 33.3282 48.5; 3159 71.5 32.7548 48.5;
    3160 78.5 32.2531 48.5; 3161 86.5 31.6797 48.5; 3162 93.5 31.3916 48.5;
    3163 101.5 31.3066 48.5; 3164 108.5 31.2321 48.5; 3165 116.5 31.147 48.5;
    3166 123.5 31.1777 48.5; 3167 131.5 31.3329 48.5; 3168 138.5 31.4686 48.5;
    3169 146.5 31.6238 48.5; 3170 153.5 31.9595 48.5; 3171 161.5 32.5718 48.5;
    3172 168.5 33.1076 48.5; 3173 176.5 33.7199 48.5; 3174 41.5 35.8547 40.5;
    3175 48.5 35.315 40.5; 3176 3.5 41.7401 18.5; 3177 11.5 41.0857 18.5;
    3178 18.5 40.5131 18.5; 3179 26.5 39.8587 18.5; 3180 33.5 39.2448 18.5;
    3181 41.5 38.4961 18.5; 3182 48.5 37.8409 18.5; 3183 56.5 37.0922 18.5;
    3184 63.5 36.3991 18.5; 3185 71.5 34.9101 25.5; 3186 78.5 34.2336 25.5;
    3187 86.5 33.4606 25.5; 3188 93.5 33.0697 25.5; 3189 101.5 32.9492 25.5;
    3190 108.5 32.8438 25.5; 3191 116.5 32.7233 25.5; 3192 123.5 32.7405 25.5;
    3193 131.5 32.9003 25.5; 3194 138.5 33.0401 25.5; 3195 146.5 33.1999 25.5;
    3196 153.5 33.6073 25.5; 3197 161.5 34.3786 25.5; 3198 168.5 35.0535 25.5;
    3199 176.5 35.8247 25.5; 3200 3.5 38.4175 40.5; 3201 11.5 37.9114 40.5;
    3202 18.5 37.4687 40.5; 3203 26.5 36.9626 40.5; 3204 33.5 36.4714 40.5;
    3205 56.5 34.6983 40.5; 3206 63.5 34.1487 40.5; 3207 71.5 33.5092 40.5;
    3208 78.5 32.9496 40.5; 3209 86.5 32.3101 40.5; 3210 93.5 31.9862 40.5;
    3211 101.5 31.8855 40.5; 3212 108.5 31.7974 40.5; 3213 116.5 31.6967 40.5;
    3214 123.5 31.7226 40.5; 3215 131.5 31.8825 40.5; 3216 138.5 32.0223 40.5;
    3217 146.5 32.1822 40.5; 3218 153.5 32.5428 40.5; 3219 161.5 33.2074 40.5;
    3220 168.5 33.7888 40.5; 3221 176.5 34.4534 40.5; 3222 3.5 36.1413 55.5;
    3223 11.5 35.7119 55.5; 3224 18.5 35.3361 55.5; 3225 26.5 34.9067 55.5;
    3226 33.5 34.4991 55.5; 3227 41.5 33.997 55.5; 3228 48.5 33.5576 55.5;
    3229 56.5 33.0554 55.5; 3230 63.5 32.6083 55.5; 3231 71.5 32.0883 55.5;
    3232 78.5 31.6334 55.5; 3233 86.5 31.1135 55.5; 3234 93.5 30.8567 55.5;
    3235 101.5 30.7897 55.5; 3236 108.5 30.7311 55.5; 3237 116.5 30.6641 55.5;
    3238 123.5 30.6991 55.5; 3239 131.5 30.846 55.5; 3240 138.5 30.9746 55.5;
    3241 146.5 31.1215 55.5; 3242 153.5 31.4355 55.5; 3243 161.5 32.0062 55.5;
    3244 168.5 32.5056 55.5; 3245 176.5 33.0763 55.5; 3346 181.5 34.4382 46;
    3347 192.5 36.008 46; 3348 197.5 36.7216 46; 3349 208.5 38.2915 46;
    3350 211.5 38.7633 46; 3351 222.5 40.6539 46; 3352 227.5 41.5132 46;
    3353 227.5 44.1006 31; 3354 222.5 43.0888 31; 3355 211.5 40.8628 31;
    3356 181.5 35.8881 31; 3357 192.5 37.691 31; 3358 197.5 38.5105 31;
    3359 208.5 40.3134 31; 3360 238.5 49.2487 16; 3361 238.5 46.3266 31;
    3362 238.5 43.4038 46; 3363 181.5 37.3373 16; 3364 192.5 39.3684 16;
    3365 197.5 40.2916 16; 3366 208.5 42.3227 16; 3367 211.5 42.9496 16;
    3368 222.5 45.5159 16; 3369 227.5 46.6824 16; 3370 181.5 33.2735 58;
    3371 192.5 34.6219 58; 3372 197.5 35.2348 58; 3373 208.5 36.5831 58;
    3374 211.5 36.993 58; 3375 222.5 38.6502 58; 3376 227.5 39.4035 58;
    3377 227.5 42.0351 43; 3378 222.5 41.1471 43; 3379 211.5 39.1933 43;
    3380 181.5 34.7287 43; 3381 192.5 36.3491 43; 3382 197.5 37.0856 43;
    3383 208.5 38.7059 43; 3384 238.5 46.911 28; 3385 238.5 43.9889 43;
    3386 238.5 41.0608 58; 3387 181.5 36.1779 28; 3388 192.5 38.0264 28;
    3389 197.5 38.8667 28; 3390 208.5 40.7152 28; 3391 211.5 41.2801 28;
    3392 222.5 43.5742 28; 3393 227.5 44.6169 28;
    MEMBER INCIDENCES
    1 1 2; 2 2 3; 3 3 4; 4 4 5; 5 5 6; 6 6 7; 7 7 8; 8 8 9; 9 9 731; 10 10 732;
    11 11 733; 12 12 734; 13 13 735; 14 14 736; 15 16 501; 16 17 511; 17 18 516;
    18 19 521; 19 20 526; 20 21 531; 21 22 536; 22 23 541; 23 24 546; 24 25 551;
    25 26 556; 26 27 561; 27 28 566; 28 29 571; 29 144 576; 30 143 737; 31 1 203;
    32 2 204; 33 3 205; 34 4 206; 35 5 207; 36 6 208; 37 7 212; 38 8 179; 39 9 180;
    40 10 181; 41 11 182; 42 12 183; 43 13 184; 44 14 185; 45 143 186; 46 32 187;
    53 42 56; 54 43 57; 55 44 58; 56 45 59; 57 46 60; 58 47 61; 59 48 62;
    60 56 1541; 61 57 1542; 62 58 1787; 63 59 2140; 64 60 2141; 65 61 2142;
    66 62 2143; 67 63 101; 68 65 102; 69 67 103; 70 69 104; 71 71 95; 72 73 105;
    73 75 96; 74 77 106; 75 79 97; 76 81 107; 77 83 98; 78 85 108; 79 87 99;
    80 89 109; 82 93 110; 83 95 410; 84 96 416; 85 97 422; 86 98 428; 87 99 434;
    89 101 440; 90 102 446; 91 103 452; 92 104 458; 93 105 464; 94 106 470;
    95 107 476; 96 108 482; 97 109 488; 98 110 494; 99 111 16; 101 115 18;
    102 117 19; 104 121 21; 105 123 22; 107 127 24; 109 131 26; 110 133 27;
    112 137 29; 113 139 144; 114 140 142; 115 142 1543; 133 179 686; 134 180 687;
    135 181 688; 136 182 689; 137 183 690; 138 184 691; 139 185 692; 140 186 693;
    141 187 694; 156 180 179; 164 203 695; 165 204 696; 166 205 697; 167 206 698;
    168 207 699; 169 208 700; 170 203 204; 171 204 205; 172 205 206; 173 206 207;
    174 207 208; 176 212 701; 177 208 212; 178 212 179; 275 405 20; 276 406 405;
    277 407 406; 278 408 407; 279 409 408; 280 410 409; 281 411 22; 282 412 411;
    283 413 412; 284 414 413; 285 415 414; 286 416 415; 287 417 24; 288 418 417;
    289 419 418; 290 420 419; 291 421 420; 292 422 421; 293 423 26; 294 424 423;
    295 425 424; 296 426 425; 297 427 426; 298 428 427; 299 429 28; 300 430 429;
    301 431 430; 302 432 431; 303 433 432; 304 434 433; 305 435 16; 306 436 435;
    307 437 436; 308 438 437; 309 439 438; 310 440 439; 311 441 17; 312 442 441;
    313 443 442; 314 444 443; 315 445 444; 316 446 445; 317 447 18; 318 448 447;
    319 449 448; 320 450 449; 321 451 450; 322 452 451; 323 453 19; 324 454 453;
    325 455 454; 326 456 455; 327 457 456; 328 458 457; 329 459 21; 330 460 459;
    331 461 460; 332 462 461; 333 463 462; 334 464 463; 335 465 23; 336 466 465;
    337 467 466; 338 468 467; 339 469 468; 340 470 469; 341 471 25; 342 472 471;
    343 473 472; 344 474 473; 345 475 474; 346 476 475; 347 477 27; 348 478 477;
    349 479 478; 350 480 479; 351 481 480; 352 482 481; 353 483 29; 354 484 483;
    355 485 484; 356 486 485; 357 487 486; 358 488 487; 359 489 31; 360 490 489;
    361 491 490; 362 492 491; 363 493 492; 364 494 493; 365 495 144; 366 496 495;
    367 497 496; 368 498 497; 369 499 498; 370 500 499; 382 483 581; 383 495 586;
    390 429 591; 397 477 596; 404 423 601; 411 471 606; 418 417 611; 419 106 97;
    420 470 422; 421 469 421; 422 468 420; 423 467 419; 424 466 418; 425 465 616;
    426 96 106; 427 416 470; 428 415 469; 429 414 468; 430 413 467; 431 412 466;
    432 411 621; 433 105 96; 434 464 416; 435 463 415; 436 462 414; 437 461 413;
    438 460 412; 439 459 626; 440 95 105; 441 410 464; 442 409 463; 443 408 462;
    444 407 461; 445 406 460; 446 405 631; 447 104 95; 448 458 410; 449 457 409;
    450 456 408; 451 455 407; 452 454 406; 453 453 636; 454 103 104; 455 452 458;
    456 451 457; 457 450 456; 458 449 455; 459 448 454; 460 447 641; 461 102 103;
    462 446 452; 463 445 451; 464 444 450; 465 443 449; 466 442 448; 467 441 646;
    468 101 102; 469 440 446; 470 439 445; 471 438 444; 472 437 443; 473 436 442;
    474 435 506; 475 501 502; 476 502 503; 477 503 504; 478 504 505; 479 505 17;
    480 506 507; 481 507 508; 482 508 509; 483 509 510; 484 510 441; 485 506 501;
    486 507 502; 487 508 503; 488 509 504; 489 510 505; 490 511 512; 491 512 513;
    492 513 514; 493 514 515; 494 515 18; 495 516 517; 496 517 518; 497 518 519;
    498 519 520; 499 520 19; 500 521 522; 501 522 523; 502 523 524; 503 524 525;
    504 525 20; 505 526 527; 506 527 528; 507 528 529; 508 529 530; 509 530 21;
    510 531 532; 511 532 533; 512 533 534; 513 534 535; 514 535 22; 515 536 537;
    516 537 538; 517 538 539; 518 539 540; 519 540 23; 520 541 542; 521 542 543;
    522 543 544; 523 544 545; 524 545 24; 525 546 547; 526 547 548; 527 548 549;
    528 549 550; 529 550 25; 530 551 552; 531 552 553; 532 553 554; 533 554 555;
    534 555 26; 535 556 557; 536 557 558; 537 558 559; 538 559 560; 539 560 27;
    540 561 562; 541 562 563; 542 563 564; 543 564 565; 544 565 28; 545 566 567;
    546 567 568; 547 568 569; 548 569 570; 549 570 29; 550 571 572; 551 572 573;
    552 573 574; 553 574 575; 554 575 144; 555 576 577; 556 577 578; 557 578 579;
    558 579 580; 559 580 31; 560 581 582; 561 582 583; 562 583 584; 563 584 585;
    564 585 495; 565 586 587; 566 587 588; 567 588 589; 568 589 590; 569 590 489;
    570 591 592; 571 592 593; 572 593 594; 573 594 595; 574 595 483; 575 596 597;
    576 597 598; 577 598 599; 578 599 600; 579 600 429; 580 601 602; 581 602 603;
    582 603 604; 583 604 605; 584 605 477; 585 606 607; 586 607 608; 587 608 609;
    588 609 610; 589 610 423; 590 611 612; 591 612 613; 592 613 614; 593 614 615;
    594 615 471; 595 616 617; 596 617 618; 597 618 619; 598 619 620; 599 620 417;
    600 621 622; 601 622 623; 602 623 624; 603 624 625; 604 625 465; 605 626 627;
    606 627 628; 607 628 629; 608 629 630; 609 630 411; 610 631 632; 611 632 633;
    612 633 634; 613 634 635; 614 635 459; 615 636 637; 616 637 638; 617 638 639;
    618 639 640; 619 640 405; 620 641 642; 621 642 643; 622 643 644; 623 644 645;
    624 645 453; 625 646 647; 626 647 648; 627 648 649; 628 649 650; 629 650 447;
    630 646 511; 631 647 512; 632 648 513; 633 649 514; 634 650 515; 635 641 516;
    636 642 517; 637 643 518; 638 644 519; 639 645 520; 640 636 521; 641 637 522;
    642 638 523; 643 639 524; 644 640 525; 645 631 526; 646 632 527; 647 633 528;
    648 634 529; 649 635 530; 650 626 531; 651 627 532; 652 628 533; 653 629 534;
    654 630 535; 655 621 536; 656 622 537; 657 623 538; 658 624 539; 659 625 540;
    660 616 541; 661 617 542; 662 618 543; 663 619 544; 664 620 545; 665 611 546;
    666 612 547; 667 613 548; 668 614 549; 669 615 550; 670 606 551; 671 607 552;
    672 608 553; 673 609 554; 674 610 555; 675 601 556; 676 602 557; 677 603 558;
    678 604 559; 679 605 560; 680 596 561; 681 597 562; 682 598 563; 683 599 564;
    684 600 565; 685 591 566; 686 592 567; 687 593 568; 688 594 569; 689 595 570;
    690 581 571; 691 582 572; 692 583 573; 693 584 574; 694 585 575; 695 586 576;
    696 587 577; 697 588 578; 698 589 579; 699 590 580; 701 653 500; 720 686 1758;
    721 687 1759; 722 688 2144; 723 689 2145; 724 690 2146; 725 691 2147;
    726 692 2148; 727 693 2149; 728 694 2150; 729 695 1544; 730 696 1545;
    731 697 1546; 732 698 1547; 733 699 1548; 734 700 1549; 735 701 1550;
    736 695 1394; 737 696 1398; 738 697 1402; 739 698 1406; 740 699 1410;
    741 700 1414; 742 701 1754; 743 686 1757; 765 731 10; 766 732 11; 767 733 12;
    768 734 13; 769 735 14; 770 736 143; 771 737 32; 772 731 1112; 773 608 831;
    774 733 1114; 775 734 1116; 776 735 1118; 777 736 1120; 778 737 1122;
    821 822 613; 822 823 822; 823 824 823; 824 825 824; 825 826 825; 826 827 877;
    827 828 827; 828 829 828; 829 830 829; 830 831 830; 831 832 603; 832 833 832;
    833 834 833; 834 835 834; 835 836 835; 836 837 598; 837 838 837; 838 839 838;
    839 840 839; 840 841 840; 841 842 593; 842 843 842; 843 844 843; 844 845 844;
    845 846 845; 846 847 583; 847 848 847; 848 849 848; 849 850 849; 850 851 850;
    851 852 588; 852 853 852; 853 854 853; 854 855 854; 855 856 855; 863 872 836;
    864 873 841; 865 874 846; 866 875 851; 867 876 856; 868 877 1172; 875 878 826;
    876 97 878; 877 878 107; 878 107 877; 879 877 98; 880 98 872; 881 872 108;
    882 108 873; 883 873 99; 884 99 874; 885 874 109; 886 109 875; 887 875 653;
    888 653 876; 889 876 110; 890 422 826; 891 826 476; 892 476 827; 893 827 428;
    894 428 836; 895 836 482; 896 482 841; 897 841 434; 898 434 846; 899 846 488;
    900 488 851; 901 851 500; 902 500 856; 903 856 494; 904 421 825; 905 825 475;
    906 475 828; 907 828 427; 908 427 835; 909 835 481; 910 481 840; 911 840 433;
    912 433 845; 913 845 487; 914 487 850; 915 850 499; 916 499 855; 917 855 493;
    918 420 824; 919 824 474; 920 474 829; 921 829 426; 922 426 834; 923 834 480;
    924 480 839; 925 839 432; 926 432 844; 927 844 486; 928 486 849; 929 849 498;
    930 498 854; 931 854 492; 932 419 823; 933 823 473; 934 473 830; 935 830 425;
    936 425 833; 937 833 479; 938 479 838; 939 838 431; 940 431 843; 941 843 485;
    942 485 848; 943 848 497; 944 497 853; 945 853 491; 946 418 822; 947 822 472;
    948 472 831; 949 831 424; 950 424 832; 951 832 478; 952 478 837; 953 837 430;
    954 430 842; 955 842 484; 956 484 847; 957 847 496; 958 496 852; 959 852 490;
    1029 1018 1173; 1030 1019 1174; 1031 1020 1175; 1032 1021 1176; 1033 1022 1177;
    1034 1023 1178; 1035 1024 1179; 1036 1025 1180; 1037 1026 1760; 1038 1027 1181;
    1039 1028 1761; 1040 1029 1762; 1041 1030 2151; 1042 1031 1182; 1043 1032 2152;
    1044 1033 2153; 1045 1034 2154; 1046 1035 1183; 1047 1036 2155; 1048 1037 2156;
    1049 1038 2157; 1050 1039 1184; 1051 1040 2158; 1052 1041 2159; 1053 1042 2160;
    1054 1043 1185; 1055 1044 1551; 1056 1045 1552; 1057 1046 1553; 1058 1047 1186;
    1059 1048 1554; 1060 1049 1555; 1061 1050 1556; 1062 1051 1187; 1063 1052 1557;
    1064 1053 1558; 1065 1054 1559; 1066 1055 1188; 1067 1056 1560; 1068 1057 1561;
    1069 1058 1189; 1070 1059 2161; 1071 1060 2162; 1072 1061 1190; 1073 1062 2163;
    1074 1063 2164; 1075 1064 1191; 1076 1065 2165; 1077 1066 2166; 1078 1067 1192;
    1079 1068 2167; 1080 1069 2168; 1081 1070 1193; 1082 1071 2169; 1083 1072 2170;
    1084 1073 1194; 1085 1074 2171; 1086 1075 2172; 1087 1076 2173; 1088 1077 2174;
    1089 1078 2175; 1090 1045 1418; 1091 1044 1419; 1092 1043 1423; 1093 1046 1427;
    1094 142 1519; 1095 1025 1432; 1096 1049 1436; 1097 1048 1437; 1098 1047 1441;
    1099 1050 1445; 1100 56 1527; 1101 1018 1450; 1102 1053 1454; 1103 1052 1458;
    1104 1051 1462; 1105 1054 1466; 1106 57 1470; 1107 1019 1474; 1108 1057 1705;
    1109 1056 1709; 1110 1055 1713; 1111 1026 1716; 1112 58 1719; 1113 1020 1722;
    1114 1029 1829; 1115 1028 1831; 1116 1027 1833; 1117 1060 1835; 1118 1059 1837;
    1119 1058 1839; 1120 1021 1893; 1121 59 1895; 1122 1030 1897; 1123 1076 1899;
    1124 1077 1901; 1125 1078 1903; 1126 1033 1905; 1127 1032 1907; 1128 1031 1909;
    1129 1063 2069; 1130 1062 2071; 1131 1061 2073; 1132 60 2075; 1133 1034 2077;
    1134 1022 2079; 1135 1066 2081; 1136 1065 2083; 1137 1064 2085; 1138 1037 2087;
    1139 1036 2089; 1140 1035 2091; 1141 1069 2093; 1142 1068 2095; 1143 1067 2097;
    1144 1038 2099; 1145 61 2101; 1146 1023 2103; 1147 1072 2105; 1148 1071 2107;
    1149 1070 2109; 1150 1041 2111; 1151 1040 2113; 1152 1039 2115; 1153 1075 2117;
    1154 1074 2119; 1155 1073 2121; 1170 1111 2176; 1171 1112 1111; 1172 1113 2177;
    1173 1114 1113; 1174 1115 2178; 1175 1116 1115; 1176 1117 2179; 1177 1118 1117;
    1178 1119 2180; 1179 1120 1119; 1180 1121 2181; 1181 1122 1121; 1182 1123 732;
    1183 1124 1123; 1184 687 1841; 1185 180 1112; 1186 1111 1843; 1187 1112 181;
    1188 181 1123; 1189 688 1911; 1190 1123 182; 1191 1124 1913; 1192 182 1114;
    1193 689 1915; 1194 1114 183; 1195 1113 2123; 1196 183 1116; 1197 690 2125;
    1198 1116 184; 1199 1115 2127; 1200 184 1118; 1201 691 2129; 1202 1118 185;
    1203 1117 2131; 1204 185 1120; 1205 692 2133; 1206 1120 186; 1207 1119 2135;
    1208 186 1122; 1209 693 2137; 1210 1122 187; 1211 1121 2139; 1235 1172 1078;
    1236 1173 104; 1237 1174 105; 1238 1175 106; 1239 1176 107; 1240 1177 108;
    1241 1178 109; 1242 1179 110; 1243 1180 102; 1244 1181 97; 1245 1182 98;
    1246 1183 99; 1247 1184 653; 1248 1185 101; 1249 1186 103; 1250 1187 95;
    1251 1188 96; 1252 1189 878; 1253 1190 872; 1254 1191 873; 1255 1192 874;
    1256 1193 875; 1257 1194 876; 1258 1185 1180; 1259 1180 1186; 1260 1186 1173;
    1261 1173 1187; 1262 1187 1174; 1263 1174 1188; 1264 1188 1175; 1265 1175 1181;
    1266 1181 1189; 1267 1189 1176; 1268 1176 1172; 1269 1172 1182; 1270 1182 1190;
    1271 1190 1177; 1272 1177 1191; 1273 1191 1183; 1274 1183 1192; 1275 1192 1178;
    1276 1178 1193; 1277 1193 1184; 1278 1184 1194; 1279 1194 1179; 1376 1391 696;
    1377 1392 1391; 1378 1393 1392; 1379 1394 1393; 1380 1395 697; 1381 1396 1395;
    1382 1397 1396; 1383 1398 1397; 1384 1399 698; 1385 1400 1399; 1386 1401 1400;
    1387 1402 1401; 1388 1403 699; 1389 1404 1403; 1390 1405 1404; 1391 1406 1405;
    1392 1407 700; 1393 1408 1407; 1394 1409 1408; 1395 1410 1409; 1396 1411 701;
    1397 1412 1411; 1398 1413 1412; 1399 1414 1413; 1400 1415 1046; 1401 1416 1415;
    1402 1417 1416; 1403 1418 1417; 1404 1419 1479; 1405 1420 1025; 1406 1421 1420;
    1407 1422 1421; 1408 1423 1422; 1409 1424 1049; 1410 1425 1424; 1411 1426 1425;
    1412 1427 1426; 1413 1428 1048; 1414 1429 1047; 1415 1430 1429; 1416 1431 1430;
    1417 1432 1431; 1418 1433 1050; 1419 1434 1433; 1420 1435 1434; 1421 1436 1435;
    1422 1437 1504; 1423 1438 1018; 1424 1439 1438; 1425 1440 1439; 1426 1441 1440;
    1427 1442 1053; 1428 1443 1442; 1429 1444 1443; 1430 1445 1444; 1431 1446 1052;
    1432 1447 1051; 1433 1448 1447; 1434 1449 1448; 1435 1450 1449; 1436 1451 1054;
    1437 1452 1451; 1438 1453 1452; 1439 1454 1453; 1440 1455 57; 1441 1456 1455;
    1442 1457 1456; 1443 1458 1457; 1444 1459 1019; 1445 1460 1459; 1446 1461 1460;
    1447 1462 1461; 1448 1463 1057; 1449 1464 1463; 1450 1465 1464; 1451 1466 1465;
    1452 1467 1056; 1453 1468 1467; 1454 1469 1468; 1455 1470 1469; 1456 1471 1055;
    1457 1472 1471; 1458 1473 1472; 1459 1474 1473; 1543 1479 1509; 1556 1502 1428;
    1557 1503 1446; 1558 1504 1533; 1561 1509 1520; 1567 1514 1502; 1574 1519 1514;
    1575 1520 142; 1579 1527 1538; 1580 1528 56; 1583 1533 1528; 1586 1538 1503;
    1587 1418 3102; 1588 1417 3103; 1589 1416 3104; 1590 1415 3105; 1591 1427 3106;
    1592 1426 3107; 1593 1425 3108; 1594 1424 3109; 1595 1436 3110; 1596 1401 3111;
    1597 1400 3112; 1598 1399 3113; 1599 1406 3114; 1600 1405 3115; 1601 1404 3116;
    1602 1403 3117; 1603 1410 3118; 1604 1409 3119; 1605 1408 3120; 1606 1407 3121;
    1607 1414 3122; 1608 1413 3123; 1609 1412 3124; 1610 1411 3125; 1611 1418 3126;
    1612 1417 3127; 1613 1416 3128; 1614 1415 3129; 1615 1427 3130; 1616 1426 3131;
    1617 1425 3132; 1618 1424 3133; 1619 1436 3134; 1620 1435 3135; 1621 1434 3136;
    1622 1433 3137; 1623 1445 3138; 1624 1444 3139; 1625 1443 3140; 1626 1442 3141;
    1627 1454 3142; 1628 1453 3143; 1629 1452 3144; 1630 1451 3145; 1631 1466 3146;
    1632 1465 3147; 1633 1464 3148; 1634 1463 3149; 1635 1419 3150; 1636 1479 3151;
    1637 1509 3152; 1638 1520 3153; 1639 1519 3154; 1640 1514 3155; 1641 1502 3156;
    1642 1428 3157; 1643 1437 3158; 1644 1504 3159; 1645 1533 3160; 1646 1528 3161;
    1647 1527 3162; 1648 1538 3163; 1649 1503 3164; 1650 1446 3165; 1651 1458 3166;
    1652 1457 3167; 1653 1456 3168; 1654 1455 3169; 1655 1470 3170; 1656 1469 3171;
    1657 1468 3172; 1658 1467 3173; 1659 1539 3174; 1660 1540 3175; 1661 1539 1540;
    1662 1541 1018; 1663 1542 1019; 1664 1543 1025; 1665 1544 1045; 1666 1545 1046;
    1667 1546 1049; 1668 1547 1050; 1669 1548 1053; 1670 1549 1054; 1671 1550 1057;
    1672 1551 1043; 1673 1552 1044; 1674 1553 142; 1675 1554 1047; 1676 1555 1048;
    1677 1556 56; 1678 1557 1051; 1679 1558 1052; 1680 1559 57; 1681 1560 1055;
    1682 1561 1056; 1683 1562 3176; 1684 1563 3177; 1685 1564 3178; 1686 1565 3179;
    1687 1566 3180; 1688 1567 3181; 1689 1568 3182; 1690 1569 3183; 1691 1570 3184;
    1692 1571 3185; 1693 1572 3186; 1694 1573 3187; 1695 1574 3188; 1696 1575 3189;
    1697 1576 3190; 1698 1577 3191; 1699 1578 3192; 1700 1579 3193; 1701 1580 3194;
    1702 1581 3195; 1703 1582 3196; 1704 1583 3197; 1705 1584 3198; 1706 1585 3199;
    1707 1586 3200; 1708 1587 3201; 1709 1588 3202; 1710 1589 3203; 1711 1590 3204;
    1712 1591 3205; 1713 1592 3206; 1714 1593 3207; 1715 1594 3208; 1716 1595 3209;
    1717 1596 3210; 1718 1597 3211; 1719 1598 3212; 1720 1599 3213; 1721 1600 3214;
    1722 1601 3215; 1723 1602 3216; 1724 1603 3217; 1725 1604 3218; 1726 1605 3219;
    1727 1606 3220; 1728 1607 3221; 1729 1608 3222; 1730 1609 3223; 1731 1610 3224;
    1732 1611 3225; 1733 1612 3226; 1734 1613 3227; 1735 1614 3228; 1736 1615 3229;
    1737 1616 3230; 1738 1617 3231; 1739 1618 3232; 1740 1619 3233; 1741 1620 3234;
    1742 1621 3235; 1743 1622 3236; 1744 1623 3237; 1745 1624 3238; 1746 1625 3239;
    1747 1626 3240; 1748 1627 3241; 1749 1628 3242; 1750 1629 3243; 1751 1630 3244;
    1752 1631 3245; 1753 1544 1562; 1754 1563 1564; 1755 1565 1545; 1756 1545 1566;
    1757 1567 1568; 1758 1569 1546; 1759 1546 1570; 1760 1571 1572; 1761 1573 1547;
    1762 1547 1574; 1763 1575 1576; 1764 1577 1548; 1765 1548 1578; 1766 1579 1580;
    1767 1581 1549; 1768 1549 1582; 1769 1583 1584; 1770 1585 1550; 1771 1552 1586;
    1772 1587 1588; 1773 1589 1553; 1774 1553 1590; 1776 1591 1555; 1777 1555 1592;
    1778 1593 1594; 1779 1595 1556; 1780 1556 1596; 1781 1597 1598; 1782 1599 1558;
    1783 1558 1600; 1784 1601 1602; 1785 1603 1559; 1786 1559 1604; 1787 1605 1606;
    1788 1607 1561; 1789 1551 1608; 1790 1609 1610; 1791 1611 1543; 1792 1543 1612;
    1793 1613 1614; 1794 1615 1554; 1795 1554 1616; 1796 1617 1618; 1797 1619 1541;
    1798 1541 1620; 1799 1621 1622; 1800 1623 1557; 1801 1557 1624; 1802 1625 1626;
    1803 1627 1542; 1804 1542 1628; 1805 1629 1630; 1806 1631 1560; 1842 1702 1026;
    1843 1703 1702; 1844 1704 1703; 1845 1705 1704; 1846 1706 58; 1847 1707 1706;
    1848 1708 1707; 1849 1709 1708; 1850 1710 1020; 1851 1711 1710; 1852 1712 1711;
    1853 1713 1712; 1854 1714 1732; 1855 1715 1714; 1856 1716 1715; 1857 1717 1733;
    1858 1718 1717; 1859 1719 1718; 1860 1720 1734; 1861 1721 1720; 1862 1722 1721;
    1863 1709 3346; 1864 1708 3347; 1865 1707 3348; 1866 1706 3349; 1867 1719 3350;
    1868 1718 3351; 1869 1717 3352; 1870 1714 3353; 1871 1715 3354; 1872 1716 3355;
    1873 1705 3356; 1874 1704 3357; 1875 1703 3358; 1876 1702 3359; 1881 1731 687;
    1882 1732 1029; 1883 1733 1028; 1884 1734 1027; 1885 1731 3360; 1886 1732 3361;
    1887 1733 3362; 1896 1751 686; 1897 1752 1751; 1898 1753 1752; 1899 1754 1753;
    1900 1755 1731; 1901 1756 1755; 1902 1757 1756; 1903 1754 3363; 1904 1753 3364;
    1905 1752 3365; 1906 1751 3366; 1907 1757 3367; 1908 1756 3368; 1909 1755 3369;
    1910 1758 1026; 1911 1759 1029; 1912 1760 58; 1913 1761 1027; 1914 1762 1028;
    1915 1763 3370; 1916 1764 3371; 1917 1765 3372; 1918 1766 3373; 1919 1767 3374;
    1920 1768 3375; 1921 1769 3376; 1922 1770 3377; 1923 1771 3378; 1924 1772 3379;
    1925 1773 3380; 1926 1774 3381; 1927 1775 3382; 1928 1776 3383; 1929 1777 3384;
    1930 1778 3385; 1931 1779 3386; 1932 1780 3387; 1933 1781 3388; 1934 1782 3389;
    1935 1783 3390; 1936 1784 3391; 1937 1785 3392; 1938 1786 3393; 1939 1550 1780;
    1940 1781 1782; 1941 1783 1758; 1942 1758 1784; 1943 1785 1786; 1944 1777 1759;
    1945 1561 1773; 1946 1774 1775; 1947 1776 1760; 1948 1760 1772; 1949 1771 1770;
    1950 1778 1762; 1951 1779 1761; 1952 1768 1769; 1953 1787 1020; 1954 1767 1787;
    1955 1787 1766; 1956 1764 1765; 1957 1560 1763; 1978 1828 1060; 1979 1829 1828;
    1980 1830 1059; 1981 1831 1830; 1982 1832 1058; 1983 1833 1832; 1984 1834 1030;
    1985 1835 1834; 1986 1836 59; 1987 1837 1836; 1988 1838 1021; 1989 1839 1838;
    1990 1840 1111; 1991 1841 1840; 1992 1842 688; 1993 1843 1842; 1994 1841 2630;
    1995 1840 2631; 1996 1829 2632; 1997 1828 2633; 1998 1831 2634; 1999 1832 2635;
    2000 1839 2636; 2001 1843 2637; 2002 1835 2638; 2003 1842 2639; 2004 1834 2640;
    2005 1836 2641; 2030 1892 1078; 2031 1893 1892; 2032 1894 1077; 2033 1895 1894;
    2034 1896 1076; 2035 1897 1896; 2036 1898 1033; 2037 1899 1898; 2038 1900 1032;
    2039 1901 1900; 2040 1902 1031; 2041 1903 1902; 2042 1904 1063; 2043 1905 1904;
    2044 1906 1062; 2045 1907 1906; 2046 1908 1061; 2047 1909 1908; 2048 1910 1124;
    2049 1911 1910; 2050 1912 689; 2051 1913 1912; 2052 1914 1113; 2053 1915 1914;
    2054 1911 2642; 2055 1897 2643; 2056 1895 2644; 2057 1894 2645; 2058 1896 2646;
    2059 1910 2647; 2060 1913 2648; 2061 1912 2649; 2062 1899 2650; 2063 1898 2651;
    2064 1901 2652; 2065 1900 2653; 2066 1915 2654; 2067 1914 2655; 2068 1905 2656;
    2069 1904 2657; 2070 1907 2658; 2071 1906 2659; 2148 2068 1034; 2149 2069 2068;
    2150 2070 60; 2151 2071 2070; 2152 2072 1022; 2153 2073 2072; 2154 2074 1065;
    2155 2075 2074; 2156 2076 1066; 2157 2077 2076; 2158 2078 1064; 2159 2079 2078;
    2160 2080 1037; 2161 2081 2080; 2162 2082 1036; 2163 2083 2082; 2164 2084 1035;
    2165 2085 2084; 2166 2086 1069; 2167 2087 2086; 2168 2088 1068; 2169 2089 2088;
    2170 2090 1067; 2171 2091 2090; 2172 2092 1038; 2173 2093 2092; 2174 2094 61;
    2175 2095 2094; 2176 2096 1023; 2177 2097 2096; 2178 2098 1072; 2179 2099 2098;
    2180 2100 1071; 2181 2101 2100; 2182 2102 1070; 2183 2103 2102; 2184 2104 1041;
    2185 2105 2104; 2186 2106 1040; 2187 2107 2106; 2188 2108 1039; 2189 2109 2108;
    2190 2110 1075; 2191 2111 2110; 2192 2112 1074; 2193 2113 2112; 2194 2114 1073;
    2195 2115 2114; 2196 2116 1042; 2197 2117 2116; 2198 2118 62; 2199 2119 2118;
    2200 2120 1024; 2201 2121 2120; 2202 2122 690; 2203 2123 2122; 2204 2124 1115;
    2205 2125 2124; 2206 2126 691; 2207 2127 2126; 2208 2128 1117; 2209 2129 2128;
    2210 2130 692; 2211 2131 2130; 2212 2132 1119; 2213 2133 2132; 2214 2134 693;
    2215 2135 2134; 2216 2136 1121; 2217 2137 2136; 2218 2138 694; 2219 2139 2138;
    2220 2123 2660; 2221 2122 2661; 2222 2069 2662; 2223 2068 2663; 2224 2071 2664;
    2225 2070 2665; 2226 2125 2666; 2227 2077 2667; 2228 2075 2668; 2229 2074 2669;
    2230 2076 2670; 2231 2124 2671; 2232 2127 2672; 2233 2126 2673; 2234 2081 2674;
    2235 2080 2675; 2236 2083 2676; 2237 2082 2677; 2238 2091 2678; 2239 2087 2679;
    2240 2129 2680; 2241 2128 2681; 2242 2086 2682; 2243 2088 2683; 2244 2131 2684;
    2245 2093 2685; 2246 2095 2686; 2247 2094 2687; 2248 2092 2688; 2249 2130 2689;
    2250 2133 2690; 2251 2099 2691; 2252 2101 2692; 2253 2132 2693; 2254 2098 2694;
    2255 2100 2695; 2256 2135 2696; 2257 2105 2697; 2258 2107 2698; 2259 2134 2699;
    2260 2104 2700; 2261 2106 2701; 2262 2137 2702; 2263 2111 2703; 2264 2113 2704;
    2265 2136 2705; 2266 2110 2706; 2267 2112 2707; 2268 2139 2708; 2269 2117 2709;
    2270 2119 2710; 2271 2138 2711; 2272 2116 2712; 2273 2118 2713; 2274 2140 1021;
    2275 2141 1022; 2276 2142 1023; 2277 2143 1024; 2278 2144 1030; 2279 2145 1033;
    2280 2146 1034; 2281 2147 1037; 2282 2148 1038; 2283 2149 1041; 2284 2150 1042;
    2285 2151 59; 2286 2152 1031; 2287 2153 1032; 2288 2154 60; 2289 2155 1035;
    2290 2156 1036; 2291 2157 61; 2292 2158 1039; 2293 2159 1040; 2294 2160 62;
    2295 2161 1058; 2296 2162 1059; 2297 2163 1061; 2298 2164 1062; 2299 2165 1064;
    2300 2166 1065; 2301 2167 1067; 2302 2168 1068; 2303 2169 1070; 2304 2170 1071;
    2305 2171 1073; 2306 2172 1074; 2307 2173 1124; 2308 2174 1076; 2309 2175 1077;
    2310 2176 1060; 2311 2177 1063; 2312 2178 1066; 2313 2179 1069; 2314 2180 1072;
    2315 2181 1075; 2316 2182 2714; 2317 2183 2715; 2318 2184 2716; 2319 2185 2717;
    2320 2186 2718; 2321 2187 2719; 2322 2188 2720; 2323 2189 2721; 2324 2190 2722;
    2325 2191 2723; 2326 2192 2724; 2327 2193 2725; 2328 2194 2726; 2329 2195 2727;
    2330 2196 2728; 2331 2197 2729; 2332 2198 2730; 2333 2199 2731; 2334 2200 2732;
    2335 2201 2733; 2336 2202 2734; 2337 2203 2735; 2338 2204 2736; 2339 2205 2737;
    2340 2206 2738; 2341 2207 2739; 2342 2208 2740; 2343 2209 2741; 2344 2210 2742;
    2345 2211 2743; 2346 2212 2744; 2347 2213 2745; 2348 2214 2746; 2349 2215 2747;
    2350 2216 2748; 2351 2217 2749; 2352 2218 2750; 2353 2219 2751; 2354 2220 2752;
    2355 2221 2753; 2356 2222 2754; 2357 2223 2755; 2358 2224 2756; 2359 2225 2757;
    2360 2226 2758; 2361 2227 2759; 2362 2228 2760; 2363 2229 2761; 2364 2230 2762;
    2365 2231 2763; 2366 2232 2764; 2367 2233 2765; 2368 2234 2766; 2369 2235 2767;
    2370 2236 2768; 2371 2237 2769; 2372 2238 2770; 2373 2239 2771; 2374 2240 2772;
    2375 2241 2773; 2376 2242 2774; 2377 2243 2775; 2378 2244 2776; 2379 2245 2777;
    2380 2246 2778; 2381 2247 2779; 2382 2248 2780; 2383 2249 2781; 2384 2250 2782;
    2385 2251 2783; 2386 2252 2784; 2387 2253 2785; 2388 2254 2786; 2389 2255 2787;
    2390 2256 2788; 2391 2257 2789; 2392 2258 2790; 2393 2259 2791; 2394 2260 2792;
    2395 2261 2793; 2396 2262 2794; 2397 2263 2795; 2398 2264 2796; 2399 2265 2797;
    2400 2183 2176; 2401 2176 2189; 2402 1759 2182; 2403 1762 2184; 2404 1761 2186;
    2405 2187 2161; 2406 2161 2188; 2407 2185 2162; 2408 2162 2190; 2409 2191 2144;
    2410 2144 2194; 2411 2192 2151; 2412 2151 2195; 2413 2193 2140; 2414 2140 2196;
    2415 2197 2175; 2416 2175 2204; 2417 2198 2174; 2418 2174 2202; 2419 2199 2173;
    2420 2173 2200; 2421 2201 2145; 2422 2145 2206; 2423 2203 2153; 2424 2208 2153;
    2425 2205 2152; 2426 2152 2210; 2427 2207 2177; 2428 2177 2212; 2429 2209 2164;
    2430 2164 2214; 2431 2211 2163; 2432 2163 2216; 2433 2213 2146; 2434 2215 2154;
    2435 2217 2141; 2436 2141 2220; 2437 2154 2219; 2438 2146 2218; 2439 2223 2178;
    2440 2178 2224; 2441 2222 2166; 2442 2166 2226; 2443 2221 2165; 2444 2165 2228;
    2445 2225 2147; 2446 2147 2232; 2447 2227 2156; 2448 2156 2231; 2449 2229 2155;
    2450 2155 2230; 2451 2233 2179; 2452 2179 2236; 2453 2234 2168; 2454 2168 2237;
    2455 2235 2167; 2456 2167 2238; 2457 2241 2148; 2458 2148 2242; 2459 2240 2157;
    2460 2157 2243; 2461 2239 2142; 2462 2142 2244; 2463 2245 2180; 2464 2180 2248;
    2465 2246 2170; 2466 2170 2249; 2467 2247 2169; 2468 2169 2250; 2469 2251 2149;
    2470 2149 2254; 2471 2252 2159; 2472 2159 2255; 2473 2253 2158; 2474 2158 2256;
    2475 2257 2181; 2476 2181 2260; 2477 2258 2172; 2478 2172 2261; 2479 2259 2171;
    2480 2171 2262; 2481 2263 2150; 2482 2264 2160; 2483 2265 2143; 2664 2630 2182;
    2665 2631 2183; 2666 2632 2184; 2667 2633 2185; 2668 2634 2186; 2669 2635 2187;
    2670 2636 2188; 2671 2637 2189; 2672 2638 2190; 2673 2639 2191; 2674 2640 2192;
    2675 2641 2193; 2676 2642 2194; 2677 2643 2195; 2678 2644 2196; 2679 2645 2197;
    2680 2646 2198; 2681 2647 2199; 2682 2648 2200; 2683 2649 2201; 2684 2650 2202;
    2685 2651 2203; 2686 2652 2204; 2687 2653 2205; 2688 2654 2206; 2689 2655 2207;
    2690 2656 2208; 2691 2657 2209; 2692 2658 2210; 2693 2659 2211; 2694 2660 2212;
    2695 2661 2213; 2696 2662 2214; 2697 2663 2215; 2698 2664 2216; 2699 2665 2217;
    2700 2666 2218; 2701 2667 2219; 2702 2668 2220; 2703 2669 2221; 2704 2670 2222;
    2705 2671 2223; 2706 2672 2224; 2707 2673 2225; 2708 2674 2226; 2709 2675 2227;
    2710 2676 2228; 2711 2677 2229; 2712 2678 2230; 2713 2679 2231; 2714 2680 2232;
    2715 2681 2233; 2716 2682 2234; 2717 2683 2235; 2718 2684 2236; 2719 2685 2237;
    2720 2686 2238; 2721 2687 2239; 2722 2688 2240; 2723 2689 2241; 2724 2690 2242;
    2725 2691 2243; 2726 2692 2244; 2727 2693 2245; 2728 2694 2246; 2729 2695 2247;
    2730 2696 2248; 2731 2697 2249; 2732 2698 2250; 2733 2699 2251; 2734 2700 2252;
    2735 2701 2253; 2736 2702 2254; 2737 2703 2255; 2738 2704 2256; 2739 2705 2257;
    2740 2706 2258; 2741 2707 2259; 2742 2708 2260; 2743 2709 2261; 2744 2710 2262;
    2745 2711 2263; 2746 2712 2264; 2747 2713 2265; 2748 2714 1829; 2749 2715 1828;
    2750 2716 1831; 2751 2717 1830; 2752 2718 1833; 2753 2719 1830; 2754 2720 1837;
    2755 2721 1835; 2756 2722 1837; 2757 2723 1834; 2758 2724 1836; 2759 2725 1838;
    2760 2726 1897; 2761 2727 1895; 2762 2728 1893; 2763 2729 1892; 2764 2730 1894;
    2765 2731 1896; 2766 2732 1899; 2767 2733 1898; 2768 2734 1901; 2769 2735 1900;
    2770 2736 1903; 2771 2737 1902; 2772 2738 1905; 2773 2739 1904; 2774 2740 1907;
    2775 2741 1906; 2776 2742 1909; 2777 2743 1908; 2778 2744 2069; 2779 2745 2068;
    2780 2746 2071; 2781 2747 2070; 2782 2748 2073; 2783 2749 2072; 2784 2750 2077;
    2785 2751 2075; 2786 2752 2079; 2787 2753 2078; 2788 2754 2074; 2789 2755 2076;
    2790 2756 2081; 2791 2757 2080; 2792 2758 2083; 2793 2759 2082; 2794 2760 2085;
    2795 2761 2084; 2796 2762 2089; 2797 2763 2089; 2798 2764 2087; 2799 2765 2086;
    2800 2766 2088; 2801 2767 2090; 2802 2768 2093; 2803 2769 2095; 2804 2770 2097;
    2805 2771 2096; 2806 2772 2094; 2807 2773 2092; 2808 2774 2099; 2809 2775 2101;
    2810 2776 2103; 2811 2777 2098; 2812 2778 2100; 2813 2779 2102; 2814 2780 2105;
    2815 2781 2107; 2816 2782 2109; 2817 2783 2104; 2818 2784 2106; 2819 2785 2108;
    2820 2786 2111; 2821 2787 2113; 2822 2788 2115; 2823 2789 2110; 2824 2790 2112;
    2825 2791 2114; 2826 2792 2117; 2827 2793 2119; 2828 2794 2121; 2829 2795 2116;
    2830 2796 2118; 2831 2797 2120; 2832 2630 2631; 2833 2714 2715; 2834 2632 2633;
    2835 2716 2717; 2836 2634 2719; 2837 2718 2635; 2838 2637 2639; 2839 2721 2723;
    2840 2638 2640; 2841 2722 2724; 2842 2720 2641; 2843 2636 2725; 2844 2642 2647;
    2845 2726 2731; 2846 2643 2646; 2847 2727 2730; 2848 2644 2645; 2849 2728 2729;
    2850 2648 2649; 2851 2732 2733; 2852 2650 2651; 2853 2734 2735; 2854 2652 2653;
    2855 2736 2737; 2856 2654 2655; 2857 2738 2739; 2858 2656 2657; 2859 2740 2741;
    2860 2658 2659; 2861 2742 2743; 2862 2660 2661; 2863 2744 2745; 2864 2662 2663;
    2865 2746 2747; 2866 2664 2665; 2867 2748 2749; 2868 2666 2671; 2869 2750 2755;
    2870 2667 2670; 2871 2751 2754; 2872 2668 2669; 2873 2752 2753; 2874 2672 2673;
    2875 2756 2757; 2876 2674 2675; 2877 2758 2759; 2878 2676 2677; 2879 2760 2761;
    2880 2680 2681; 2881 2764 2765; 2882 2679 2682; 2883 2763 2766; 2884 2762 2683;
    2885 2678 2767; 2886 2684 2689; 2887 2768 2773; 2888 2685 2688; 2889 2769 2772;
    2890 2686 2687; 2891 2770 2771; 2892 2690 2693; 2893 2774 2777; 2894 2691 2694;
    2895 2775 2778; 2896 2692 2695; 2897 2776 2779; 2898 2696 2699; 2899 2780 2783;
    2900 2697 2700; 2901 2781 2784; 2902 2698 2701; 2903 2782 2785; 2904 2702 2705;
    2905 2786 2789; 2906 2703 2706; 2907 2787 2790; 2908 2704 2707; 2909 2788 2791;
    2910 2708 2711; 2911 2792 2795; 2912 2709 2712; 2913 2793 2796; 2914 2710 2713;
    2915 2794 2797; 3066 3102 1562; 3067 3103 1563; 3068 3104 1564; 3069 3105 1565;
    3070 3106 1566; 3071 3107 1567; 3072 3108 1568; 3073 3109 1569; 3074 3110 1570;
    3075 3111 1571; 3076 3112 1572; 3077 3113 1573; 3078 3114 1574; 3079 3115 1575;
    3080 3116 1576; 3081 3117 1577; 3082 3118 1578; 3083 3119 1579; 3084 3120 1580;
    3085 3121 1581; 3086 3122 1582; 3087 3123 1583; 3088 3124 1584; 3089 3125 1585;
    3090 3126 1586; 3091 3127 1587; 3092 3128 1588; 3093 3129 1589; 3094 3130 1590;
    3095 3131 1539; 3096 3132 1540; 3097 3133 1591; 3098 3134 1592; 3099 3135 1593;
    3100 3136 1594; 3101 3137 1595; 3102 3138 1596; 3103 3139 1597; 3104 3140 1598;
    3105 3141 1599; 3106 3142 1600; 3107 3143 1601; 3108 3144 1602; 3109 3145 1603;
    3110 3146 1604; 3111 3147 1605; 3112 3148 1606; 3113 3149 1607; 3114 3150 1608;
    3115 3151 1609; 3116 3152 1610; 3117 3153 1611; 3118 3154 1612; 3119 3155 1613;
    3120 3156 1614; 3121 3157 1615; 3122 3158 1616; 3123 3159 1617; 3124 3160 1618;
    3125 3161 1619; 3126 3162 1620; 3127 3163 1621; 3128 3164 1622; 3129 3165 1623;
    3130 3166 1624; 3131 3167 1625; 3132 3168 1626; 3133 3169 1627; 3134 3170 1628;
    3135 3171 1629; 3136 3172 1630; 3137 3173 1631; 3138 3174 1514; 3139 3175 1502;
    3140 3176 1394; 3141 3177 1393; 3142 3178 1392; 3143 3179 1391; 3144 3180 1398;
    3145 3181 1397; 3146 3182 1396; 3147 3183 1395; 3148 3184 1402; 3149 3185 1435;
    3150 3186 1434; 3151 3187 1433; 3152 3188 1445; 3153 3189 1444; 3154 3190 1443;
    3155 3191 1442; 3156 3192 1454; 3157 3193 1453; 3158 3194 1452; 3159 3195 1451;
    3160 3196 1466; 3161 3197 1465; 3162 3198 1464; 3163 3199 1463; 3164 3200 1419;
    3165 3201 1479; 3166 3202 1509; 3167 3203 1520; 3168 3204 1519; 3169 3205 1428;
    3170 3206 1437; 3171 3207 1504; 3172 3208 1533; 3173 3209 1528; 3174 3210 1527;
    3175 3211 1538; 3176 3212 1503; 3177 3213 1446; 3178 3214 1458; 3179 3215 1457;
    3180 3216 1456; 3181 3217 1455; 3182 3218 1470; 3183 3219 1469; 3184 3220 1468;
    3185 3221 1467; 3186 3222 1423; 3187 3223 1422; 3188 3224 1421; 3189 3225 1420;
    3190 3226 1432; 3191 3227 1431; 3192 3228 1430; 3193 3229 1429; 3194 3230 1441;
    3195 3231 1440; 3196 3232 1439; 3197 3233 1438; 3198 3234 1450; 3199 3235 1449;
    3200 3236 1448; 3201 3237 1447; 3202 3238 1462; 3203 3239 1461; 3204 3240 1460;
    3205 3241 1459; 3206 3242 1474; 3207 3243 1473; 3208 3244 1472; 3209 3245 1471;
    3210 3176 3177; 3211 3178 3179; 3212 3180 3181; 3213 3182 3183; 3214 3184 3111;
    3215 3112 3113; 3216 3114 3115; 3217 3116 3117; 3218 3118 3119; 3219 3120 3121;
    3220 3122 3123; 3221 3124 3125; 3222 3102 3103; 3223 3104 3105; 3224 3106 3107;
    3225 3108 3109; 3226 3110 3185; 3227 3186 3187; 3228 3188 3189; 3229 3190 3191;
    3230 3192 3193; 3231 3194 3195; 3232 3196 3197; 3233 3198 3199; 3234 3126 3127;
    3235 3200 3201; 3236 3128 3129; 3237 3202 3203; 3238 3130 3131; 3239 3204 3174;
    3240 3132 3133; 3241 3175 3205; 3242 3134 3135; 3243 3206 3207; 3244 3136 3137;
    3245 3208 3209; 3246 3138 3139; 3247 3210 3211; 3248 3140 3141; 3249 3212 3213;
    3250 3142 3143; 3251 3214 3215; 3252 3144 3145; 3253 3216 3217; 3254 3146 3147;
    3255 3218 3219; 3256 3148 3149; 3257 3220 3221; 3258 3150 3151; 3259 3222 3223;
    3260 3152 3153; 3261 3224 3225; 3262 3154 3155; 3263 3226 3227; 3264 3156 3157;
    3265 3228 3229; 3266 3158 3159; 3267 3230 3231; 3268 3160 3161; 3269 3232 3233;
    3270 3162 3163; 3271 3234 3235; 3272 3164 3165; 3273 3236 3237; 3274 3166 3167;
    3275 3238 3239; 3276 3168 3169; 3277 3240 3241; 3278 3170 3171; 3279 3242 3243;
    3280 3172 3173; 3281 3244 3245; 3330 3346 1763; 3331 3347 1764; 3332 3348 1765;
    3333 3349 1766; 3334 3350 1767; 3335 3351 1768; 3336 3352 1769; 3337 3353 1770;
    3338 3354 1771; 3339 3355 1772; 3340 3356 1773; 3341 3357 1774; 3342 3358 1775;
    3343 3359 1776; 3344 3360 1777; 3345 3361 1778; 3346 3362 1779; 3347 3363 1780;
    3348 3364 1781; 3349 3365 1782; 3350 3366 1783; 3351 3367 1784; 3352 3368 1785;
    3353 3369 1786; 3354 3370 1713; 3355 3371 1712; 3356 3372 1711; 3357 3373 1710;
    3358 3374 1722; 3359 3375 1721; 3360 3376 1720; 3361 3377 1717; 3362 3378 1718;
    3363 3379 1719; 3364 3380 1709; 3365 3381 1708; 3366 3382 1707; 3367 3383 1706;
    3368 3384 1732; 3369 3385 1733; 3370 3386 1734; 3371 3387 1705; 3372 3388 1704;
    3373 3389 1703; 3374 3390 1702; 3375 3391 1716; 3376 3392 1715; 3377 3393 1714;
    3378 3363 3364; 3379 3365 3366; 3380 3367 3368; 3381 3369 3360; 3382 3387 3388;
    3383 3389 3390; 3384 3391 3392; 3385 3393 3384; 3386 3356 3357; 3387 3380 3381;
    3388 3358 3359; 3389 3382 3383; 3390 3355 3354; 3391 3379 3378; 3392 3353 3361;
    3393 3377 3385; 3394 3346 3347; 3395 3370 3371; 3396 3348 3349; 3397 3372 3373;
    3398 3350 3351; 3399 3374 3375; 3400 3352 3362; 3401 3376 3386;
    START GROUP DEFINITION
    FLOOR
    _1A 1 TO 46 60 TO 66 83 TO 87 89 TO 98 115 133 TO 141 156 164 TO 174 -
    176 TO 178 275 TO 370 382 383 390 397 404 411 418 TO 699 701 720 TO 743 765 -
    766 TO 778 821 TO 855 863 TO 868 875 TO 959 1029 TO 1155 1170 TO 1211 1235 -
    1236 TO 1279 1376 TO 1459 1543 1556 TO 1558 1561 1567 1574 1575 1579 1580 -
    1583 1586 TO 1774 1776 TO 1806 1842 TO 1876 1881 TO 1887 1896 TO 1957 1978 -
    1979 TO 2005 2030 TO 2071 2148 TO 2483 2664 TO 2915 3066 TO 3281 3330 TO 3401
    MEMBER
    END GROUP DEFINITION
    MEMBER RELEASE
    53 TO 59 67 TO 80 82 99 101 102 104 105 107 109 110 112 TO 114 END MZ
    419 TO 424 426 TO 431 433 TO 438 440 TO 445 447 TO 452 454 TO 459 461 TO 466 -
    468 TO 473 START MY MZ
    468 TO 473 END MY MZ
    485 TO 489 630 TO 699 START MY MZ
    287 485 TO 489 630 TO 699 END MY MZ
    474 1258 TO 1279 START MY MZ
    15 START MY MZ
    1258 TO 1279 END MY MZ
    17 18 20 21 23 25 26 28 29 382 383 390 397 404 411 418 425 432 439 446 453 -
    460 467 START MY MZ
    484 494 499 509 514 524 534 539 549 554 559 564 569 574 579 584 589 594 599 -
    604 609 614 619 624 629 END MY MZ
    876 878 880 882 884 886 890 TO 959 START MY MZ
    877 879 881 883 885 890 TO 959 END MY MZ
    1 TO 14 30 156 170 TO 174 177 178 736 TO 743 765 TO 771 1090 1092 TO 1096 -
    1098 TO 1102 1104 TO 1108 1110 TO 1114 1116 1117 1119 TO 1123 1125 1126 1128 -
    1129 1131 TO 1135 1137 1138 1140 1141 1143 TO 1147 1149 1150 1152 1153 1155 -
    1184 TO 1211 START MY MZ
    1 TO 14 30 156 170 TO 174 177 178 765 TO 771 1185 1187 1188 1190 1192 1194 -
    1196 1198 1200 1202 1204 1206 1208 1210 1376 1380 1384 1388 1392 1396 1400 -
    1405 1409 1414 1418 1423 1427 1432 1436 1440 1444 1448 1456 1575 1580 1842 -
    1846 1850 1881 1882 1884 1896 1978 1982 1984 1986 1988 1990 1992 2030 2034 -
    2036 2040 2042 2046 2048 2050 2052 2148 2150 2152 2156 2158 2160 2164 2166 -
    2170 2172 2174 2176 2178 2182 2184 2188 2190 2194 2196 2198 2200 2202 2204 -
    2206 2208 2210 2212 2214 2216 2218 END MY MZ
    1661 1753 TO 1774 1776 TO 1799 1801 TO 1806 3210 TO 3281 START MY MZ
    1661 1753 TO 1774 1776 TO 1799 1801 TO 1806 3210 TO 3281 END MY MZ
    1596 TO 1658 START MY MZ
    3140 END MY MZ
    3141 END MY MZ
    3142 END MY MZ
    3143 END MY MZ
    3144 END MY MZ
    3145 END MY MZ
    3146 END MY MZ
    3147 END MY MZ
    3148 END MY MZ
    3138 3139 3152 TO 3209 END MY MZ
    1587 TO 1595 START MY MZ
    3149 END MY MZ
    3150 END MY MZ
    3151 END MY MZ
    1800 START MY MZ
    1800 END MY MZ
    1939 TO 1952 1954 TO 1957 3378 TO 3401 START MY MZ
    1939 TO 1952 1954 TO 1957 3378 TO 3401 END MY MZ
    1863 TO 1876 1885 TO 1887 1903 TO 1909 START MY MZ
    3354 TO 3377 END MY MZ
    2400 TO 2421 2423 2425 2832 TO 2855 START MY MZ
    2400 TO 2421 2423 2425 2832 TO 2855 END MY MZ
    1994 TO 1998 2001 TO 2005 2054 TO 2065 START MY MZ
    2753 END MY MZ
    2754 END MY MZ
    1999 START MY MZ
    2000 START MY MZ
    2748 TO 2752 2755 TO 2771 END MY MZ
    2422 2424 2426 TO 2439 2441 2443 2856 TO 2873 START MY MZ
    2422 2424 2426 TO 2439 2441 2443 2856 TO 2873 END MY MZ
    2066 TO 2071 2220 TO 2231 START MY MZ
    2772 TO 2789 END MY MZ
    2440 2442 2444 TO 2463 2465 2467 2874 TO 2897 START MY MZ
    2440 2442 2444 TO 2463 2465 2467 2874 TO 2897 END MY MZ
    2232 TO 2237 2239 TO 2255 START MY MZ
    2796 END MY MZ
    2790 TO 2795 2797 TO 2813 END MY MZ
    2238 START MY MZ
    2464 2466 2468 TO 2483 2898 TO 2915 START MY MZ
    2464 2466 2468 TO 2483 2898 TO 2915 END MY MZ
    2256 TO 2273 START MY MZ
    2814 TO 2831 END MY MZ
    889 END MY MZ
    DEFINE MATERIAL START
    ISOTROPIC CONCRETE
    E 453600
    POISSON 0.17
    DENSITY 0.14999
    ALPHA 5.5e-006
    DAMP 0.05
    ISOTROPIC STEEL
    E 4.176e+006
    POISSON 0.3
    DENSITY 0.489024
    ALPHA 6.5e-006
    DAMP 0.03
    END DEFINE MATERIAL
    MEMBER PROPERTY AMERICAN
    53 TO 59 67 TO 80 82 99 101 102 104 105 109 110 112 TO 114 PRIS YD 2.5
    31 TO 39 60 TO 62 83 TO 85 89 TO 94 115 133 134 164 TO 169 176 275 TO 292 -
    305 TO 340 720 721 729 TO 735 1029 TO 1031 1036 TO 1040 1054 TO 1068 1236 -
    1237 TO 1238 1243 1244 1248 TO 1251 1662 TO 1682 1910 TO 1914 -
    1953 TABLE ST W40X149
    1 TO 14 30 156 170 TO 174 177 178 420 TO 424 427 TO 431 434 TO 438 -
    441 TO 445 448 TO 452 455 TO 459 462 TO 466 469 TO 473 736 737 765 TO 771 -
    1090 1092 TO 1095 1258 TO 1265 1376 TO 1383 1400 TO 1403 1405 TO 1417 1556 -
    1567 1574 TABLE ST W14X22
    419 426 433 440 447 454 461 468 876 TO 889 TABLE ST W27X84
    485 TO 489 630 TO 699 742 890 TO 959 1108 1110 1114 1116 1117 1119 TO 1123 -
    1125 1126 1128 1129 1131 1133 TO 1135 1137 1138 1140 1141 1143 1144 1146 -
    1147 1149 1150 1152 1153 1155 1184 TO 1211 1266 TO 1279 1587 TO 1661 1683 -
    1684 TO 1774 1776 TO 1806 1863 TO 1876 1885 TO 1887 1903 TO 1909 1915 TO 1952 -
    1954 TO 1957 1978 1979 1982 TO 1985 1988 TO 2005 2030 2031 2034 TO 2037 2040 -
    2041 TO 2043 2046 TO 2071 2148 2149 2152 2153 2156 TO 2161 2164 TO 2167 2170 -
    2171 TO 2174 2176 TO 2179 2182 TO 2185 2188 TO 2191 2194 TO 2197 2200 TO 2273 -
    2316 TO 2483 2664 TO 2915 3066 TO 3281 3330 TO 3401 TABLE ST W12X14
    17 20 25 28 29 382 383 390 397 404 411 418 425 432 439 446 453 460 467 474 -
    480 TO 484 495 TO 499 510 TO 514 535 TO 539 550 TO 629 TABLE ST W21X50
    40 TO 46 63 TO 66 86 87 95 TO 98 135 TO 141 293 TO 304 341 TO 370 701 722 -
    723 TO 728 772 TO 778 821 TO 855 863 TO 868 875 1032 TO 1035 1041 TO 1053 -
    1069 TO 1089 1170 TO 1183 1235 1239 TO 1242 1245 TO 1247 1252 TO 1257 2274 -
    2275 TO 2315 TABLE ST W33X118
    738 TO 741 743 1096 TO 1102 1104 TO 1107 1111 1113 1384 TO 1399 1418 TO 1430 -
    1432 TO 1439 1444 TO 1451 1456 TO 1459 1558 1580 1583 1842 TO 1846 -
    1850 TO 1856 1860 TO 1862 1881 1882 1884 1896 TO 1902 TABLE ST W14X61
    15 16 18 19 21 TO 24 26 27 107 475 TO 479 490 TO 494 500 TO 509 515 TO 534 -
    540 TO 549 TABLE ST W36X232
    1091 1103 1109 1112 1115 1118 1124 1127 1130 1132 1136 1139 1142 1145 1148 -
    1151 1154 1404 1431 1440 TO 1443 1452 TO 1455 1543 1557 1561 1575 1579 1586 -
    1847 TO 1849 1857 TO 1859 1883 1980 1981 1986 1987 2032 2033 2038 2039 2044 -
    2045 2150 2151 2154 2155 2162 2163 2168 2169 2175 2180 2181 2186 2187 2192 -
    2193 2198 2199 TABLE ST W40X199
    CONSTANTS
    MATERIAL CONCRETE MEMB 53 TO 59 67 TO 80 82 99 101 102 104 105 109 110 112 -
    113 TO 114
    MATERIAL STEEL MEMB 1 TO 46 60 TO 66 83 TO 87 89 TO 98 107 115 133 TO 141 -
    156 164 TO 174 176 TO 178 275 TO 370 382 383 390 397 404 411 418 TO 699 701 -
    720 TO 743 765 TO 778 821 TO 855 863 TO 868 875 TO 959 1029 TO 1155 1170 -
    1171 TO 1211 1235 TO 1279 1376 TO 1459 1543 1556 TO 1558 1561 1567 1574 1575 -
    1579 1580 1583 1586 TO 1774 1776 TO 1806 1842 TO 1876 1881 TO 1887 -
    1896 TO 1957 1978 TO 2005 2030 TO 2071 2148 TO 2483 2664 TO 2915 -
    SUPPORTS
    42 TO 48 63 65 67 69 71 73 75 77 79 81 83 85 87 89 93 111 115 117 121 123 -
    127 131 133 137 139 140 PINNED
    LOAD 1 LOADTYPE None TITLE DEAD LOAD
    SELFWEIGHT Y -1
    FLOOR LOAD
    _1A FLOAD -0.015 GY INCLINED
    PERFORM ANALYSIS
    PARAMETER 1
    CODE LRFD
    FYLD 7200 ALL
    CHECK CODE ALL
    FINISH
  • We notice that you are applying a FLOOR LOAD using the INCLINED option. We also notice that the entire set of members which make up the roof, which is curved in 2 planes, are clustered into a single FLOOR GROUP.
    The INCLINED FLOOR load is designed to work only when a particular instance of that command is applied on a set of members which form a single plane. As we wrote in the previous paragraph, since the roof is sloped in 2 planes in a wave like form, the roof encompasses numerous small panels each forming its own plane. It seems that each set of 4 members which form a closed region forms a plane. STAAD will not be able to generate the load when the floor group represents dozens of panels each forming its own plane. Each floor group has to represent just one plane.
    In order to make the FLOOR LOAD work on this, you would have to
    a) Replace your current floor group with several floor groups, with each floor group constituting the members of just one plane.
    b) Apply the FLOOR LOAD one such group per instance of the command.
    Here is an example.
    FLOOR
    _1001 37 7 38 178
    _1002 38 8 39 156
    _1003 39 9 772 1185
    _1004 772 765 40 1187
    SELFWEIGHT Y -1
    FLOOR LOAD
    _1001 FLOAD -0.015 GY INCLINED
    _1002 FLOAD -0.015 GY INCLINED
    _1003 FLOAD -0.015 GY INCLINED
    _1004 FLOAD -0.015 GY INCLINED
    As you may have reckoned, given the complex shape of the roof and the hundreds of panels that it encompasses, the FLOOR LOAD is not an efficient way to apply the roof load.
    A simpler way would be to define plate elements on the roof and apply the load using the element pressure load option. Each panel made up of 4 members could be circumscribed by one element. You can use the Add Plate-Quad facility in the Geometry menu of STAAD's GUI to do this. It may seem tedious, but in a short while, the whole roof would be covered using this method. You could assign the plates a very small thickness, zero density, and an E which is 1/100th that of concrete to ensure that neither the weight nor the stiffness of the plates would have any meaningful contribution to the structure. So, the plates act as nothing but a medium for applying a load.
  • All,
    I had another thought on this...
    Due to the wave-form geometry of this structure, it seems probable that some of these quads would end up being warped.  I tested a few of them, but I couldn't positively identify any that would exceed STAAD.Pro's built-in tolerance for warp in a quad plate.
    Then I got to thinking...rather than introduce all of those plates and wonder about their effect on the model (even if their stiffness WAS made negligible), how about the idea of using ELEMENT JOINT LOADS?  But the very first one that I tried proved to be even more tedious than defining plates, AND it produced an error message stating that the selected nodes form a warped plane, and it refused to create the load.
    If quad plates ARE used as a means to apply the loads as plate pressure loads, I would carefully observe the statics check results to be sure that the warped plates do not cause an unacceptable loss of load.
    Cheers,
    Chris
