Hi Ambrish,
As to what specific application are you applying your query. Is it on the Floor load? Better specify clearly.
William
Ambarish,
Staad automatically identifies the floor level by simply identifying the two coplanar beams orthogonally meeting at a column joint.
Also, manually this level can be defined by specifying the floor height.
In the model shown below , there are two floor levels at 3m and 6m.
So I have defined the floor height specification as
FLOOR HEIGHT 3.0; 6.0 DEFINE 1893 LOAD
Please find below the input command of the complete model .
STAAD SPACE START JOB INFORMATION ENGINEER DATE 10-Apr-07 END JOB INFORMATION INPUT WIDTH 79 UNIT METER KN JOINT COORDINATES 101 7 0 0; 102 7 0 3.1; 103 7 0 6.2; 104 7 0 9.3; 105 7 1.5 0; 106 7 1.5 3.1; 107 7 1.5 6.2; 108 7 1.5 9.3; 109 7 3 0; 110 7 3 3.1; 111 7 3 6.2; 112 7 3 9.3; 113 7 4.5 0; 114 7 4.5 3.1; 115 7 4.5 6.2; 116 7 4.5 9.3; 117 7 6 0; 118 7 6 3.1; 119 7 6 6.2; 120 7 6 9.3; 121 10 0 0; 122 10 0 3.1; 123 10 0 6.2; 124 10 0 9.3; 125 10 1.5 0; 126 10 1.5 3.1; 127 10 1.5 6.2; 128 10 1.5 9.3; 129 10 3 0; 130 10 3 3.1; 131 10 3 6.2; 132 10 3 9.3; 133 10 4.5 0; 134 10 4.5 3.1; 135 10 4.5 6.2; 136 10 4.5 9.3; 137 10 6 0; 138 10 6 3.1; 139 10 6 6.2; 140 10 6 9.3; MEMBER INCIDENCES 201 101 105; 202 102 106; 203 103 107; 204 104 108; 205 105 109; 206 106 110; 207 107 111; 208 108 112; 209 109 113; 210 110 114; 211 111 115; 212 112 116; 213 113 117; 214 114 118; 215 115 119; 216 116 120; 217 121 125; 218 122 126; 219 123 127; 220 124 128; 221 125 129; 222 126 130; 223 127 131; 224 128 132; 225 129 133; 226 130 134; 227 131 135; 228 132 136; 229 133 137; 230 134 138; 231 135 139; 232 136 140; 301 109 110; 302 110 111; 303 111 112; 304 117 118; 305 118 119; 306 119 120; 307 129 130; 308 130 131; 309 131 132; 310 137 138; 311 138 139; 312 139 140; 401 109 129; 402 110 130; 403 111 131; 404 112 132; 405 117 137; 406 118 138; 407 119 139; 408 120 140; DEFINE MATERIAL START ISOTROPIC CONCRETE E 2.17185e+007 POISSON 0.17 DENSITY 23.5616 ALPHA 1e-005 DAMP 0.05 END DEFINE MATERIAL MEMBER PROPERTY AMERICAN 201 TO 232 PRIS YD 0.5 ZD 0.5 301 TO 312 401 TO 408 PRIS YD 0.4 ZD 0.3 CONSTANTS MATERIAL CONCRETE ALL SUPPORTS 101 TO 104 121 TO 124 FIXED FLOOR HEIGHT 3.0; 6.0 DEFINE 1893 LOAD ZONE 0.36 RF 3 I 1.5 SS 1 ST 1 DM 0.05 DT 0 SELFWEIGHT MEMBER WEIGHT 301 TO 312 401 TO 408 UNI 15 *FLOOR WEIGHT *YRANGE 2.5 3.5 FLOAD 5 *YRANGE 5.5 6.5 FLOAD 5 LOAD 1 LOADTYPE Seismic TITLE PS_(+X) 1893 LOAD X PERFORM ANALYSIS CHANGE LOAD 2 LOADTYPE Seismic TITLE PS_(+Z) 1893 LOAD Z LOAD 3 LOADTYPE Dead TITLE DL SELFWEIGHT Y -1 MEMBER LOAD 301 TO 312 401 TO 408 UNI GY -15 FLOOR LOAD YRANGE 2.5 3.5 FLOAD -5 GY YRANGE 5.5 6.5 FLOAD -5 GY LOAD 7 LOADTYPE Seismic TITLE RS_X SELFWEIGHT X 1 SELFWEIGHT Y 1 SELFWEIGHT Z 1 MEMBER LOAD 301 TO 312 401 TO 408 UNI GX 15 301 TO 312 401 TO 408 UNI GY 15 301 TO 312 401 TO 408 UNI GZ 15 FLOOR LOAD YRANGE 2.5 3.5 FLOAD 5 GX YRANGE 2.5 3.5 FLOAD 5 GY YRANGE 2.5 3.5 FLOAD 5 GZ YRANGE 5.5 6.5 FLOAD 5 GX YRANGE 5.5 6.5 FLOAD 5 GY YRANGE 5.5 6.5 FLOAD 5 GZ SPECTRUM CQC 1893 TOR X 0.09 ACC SCALE 1 DAMP 0.05 MIS SOIL TYPE 1 LOAD 8 LOADTYPE Seismic TITLE RS_Z SPECTRUM CQC 1893 TOR Z 0.09 ACC SCALE 1 DAMP 0.05 MIS SOIL TYPE 1 LOAD COMBINATION 9 1 1.2 3 1.2 LOAD COMBINATION 10 2 1.2 3 1.2 LOAD COMBINATION 11 3 1.2 7 1.2 LOAD COMBINATION 12 3 1.2 8 1.2 PERFORM ANALYSIS PRINT STATICS CHECK FINISH
Biswa
Honestly, I've been using staad for quite sometime but havn't used the floor height command. Like what the other reply said ( thanks to you sir ) that staad automatically determines the floor height based on the intersections of beams & columns & let me add based on the yrange you specify as in the case of floor load. For me I don't need specifying the floor height. I attached also below the model replied ( by you sir, anyway thanks also ). take note the remarks with asterisks (*)
