STAAD v8i doesn't run analysis without MEMORY-command in input file. Output file then only contents of two lines:
1. STAAD SPACE ERROR NOT ENOUGH MEMORY TO START ANALYSIS. ( 41 )
But available memory should be enough. We tested with two computers (each more than4.3 GB free disk space) and evaluated the limit MEMORY 67 (with each compter). That means: MEMORY less then 68 works, MEMORY more then 67 fails. Can anybody explain that?
Thanks for a reply. Best regards, Christian.
