PREFABRICATED CONCRETE HOLLOW CORE SLAB
Hello! I am absolute beginner in STAAD, therefore would like to kindly ask anyone who could share already created .std file with PREFABRICATED CONCRETE HOLLOW CORE SLAB. Dimensions 1200x7450x220 (mm), but in my case just example would be great as well. Already in advance - thank you and a have a great Year 2010!
  • Hi and welcome to STAAD.Pro!
    I don't have any hollow core models developed yet, but it is an area of interest to me, as I have had experience designing block and plank dormitories.
    Here are my thoughts:
    If the design intent is to assume that the hollowcore plank is simply supported and spans in only one direction, I have come to the conclusion that the most efficient method of modeling these structures is to use a loading command such as FLOOR LOAD to distribute the applied loads (including allowance for self weight and topping, if any) without actually modeling the planks themselves.  Then I would model the rigid diaphragm effects with a Master - Slave  specification.
    If the design intent is to assume that the hollowcore plank ispans in multiple directions (plate action), then it would be necessary to model the plank as a mesh of plate elements, and properties would have to be provided in both plan directions.
    So let's start with those thoughts first, and if you're interested in filling me in on your design philosophy, then I can mock up a model to get you started.
    If you're interested in any of our STAAD.Pro courses, here is a link to our Learning Path that will let you know what we have to offer, what the courses cover, when and how they are delivered, etc:
    http://www.bentley.com/en-US/Training/Products/Resources/Courses/Paths/STAAD.Pro+Structural/STAAD+Structural+Training.htm
    Cheers,
    Chris
  • Hello Chris, Thanks for answer. In fact, what I need is behaviour ( under self-load and working load ) analysis of one slab - simply supported in both ends. So in case if it is possible, some model example would be really great!
  • Given your response that you are interested in modeling one simply supported plank, it has me wondering whether you are trying to design the walls/framing that support the plank, or if you are trying to simulate the behavior of the plank itself.
    If you are trying to design the supporting structure, then the model below is a very simple start.  On the other hand, if you are actually trying to simulate the plank itself, then that becomes more of a modeling exercise, and I would want to know more about what analysis results you would be looking for before I suggest some potential methods of doing this.
    Cheers,
    Chris
    STAAD SPACE
    START JOB INFORMATION
    ENGINEER DATE 30-Dec-09
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    1 0 0 0; 2 10 0 0; 3 0 5 0; 4 10 5 0; 5 0 0 8; 6 10 0 8; 7 0 5 8; 8 10 5 8;
    MEMBER INCIDENCES
    1 3 4; 2 1 3; 3 2 4; 4 7 8; 5 5 7; 6 6 8; 7 3 7; 8 4 8;
    MEMBER PROPERTY AMERICAN
    1 4 7 8 TABLE ST W18X55
    2 3 5 6 TABLE ST W14X90
    DEFINE MATERIAL START
    ISOTROPIC STEEL
    E 1.99947e+008
    POISSON 0.3
    DENSITY 76.8191
    ALPHA 6e-006
    DAMP 0.03
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL STEEL ALL
    SUPPORTS
    1 2 5 6 FIXED
    LOAD 1 LOADTYPE None TITLE LOAD CASE 1
    ONEWAY LOAD
    YRANGE 4 6 ONE -7.5 GY TOWARDS 1
    PERFORM ANALYSIS
    FINISH
  • Thanks, Chris! It is really great you doing! For now it is what I needed, so hope my STAAD skills will improve in some bright future. Wish you all the best in 2010!
  • Glad we were able to help!
    Happy New Year!
    Cheers,
    Chris
Reply Children
