Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
RAM | STAAD | ADINA
RAM | STAAD Forum
Connecting Beams
Sign In
Replies
1 reply
Subscribers
108 subscribers
Views
Users
0 members are here
beams
Connecting Beams
Henrik Jonson
over 13 years ago
Hello i am an engineering student, that was wondering if you should "merge" the beams togetther when you draw the structure in staad. I did not do this and is wondering if the stress calculation will be wrong if i don't. Should i merge every beam together to get an accurate calculation?
Chris Conrad
Sun, Feb 21 2010 2:02 PM
Hi henrikjon, The Merge command is generally used when you have a string of beam segments that could just as easily be represented by a single beam. Naturally, we would prefer to simplify the output as much as possible. So if a string of beams could be merged into one beam (and the intermediate nodes can safely be deleted), then it makes sense to merge those beams. On the other hand, if there are other members or plates framing into those intermediate nodes, or if the intermediate nodes have nodal loads applied, or if the intermediate nodes have been placed specifically to observe displacements in strategic locations, then those are all reasons why you would NOT want to merge several members into one. The results will still be accurate, regardless of whether you merge the members or not. You just may have more results data to sift through if you have unnecessary members in the model. Cheers, Chris
Cancel
Vote Up
0
Vote Down
Sign in to reply
Cancel
