I am wondering how to use the international design codes in STAAD.Pro v8i. On the start-up screen, American codes are selected with a green dot. I need to use Asian codes. When I select Asian codes, a red dot appears next to it. Is there an additional software package I need to purchase? Any and all help will be greatly appreciated.
lpotter
The red dot means that you are not currently licensed to use the selected code. If you feel that you have purchased the code, then I would recommend that you submit a Service Ticket using the following link, and be sure to indicate it as a Licensing related question.
http://www.bentley.com/serviceticketmanager/
However, if you have NOT purchased the necessary codes, you will want to speak with your sales contact, in order to upgrade.
Cheers,
Chris
