The following outline identifies new features and enhancements in this release of SSDD V8i. For more information about what's new, see "SSDD" > "Release Report" in the online help document. To open the help document in SSDD choose Help > Contents. Steel design code (GB50017) Update angle section slenderness length check. Pipe section plastic development ratio considered for stability check. Update Code item 5.2.5 for closed section, the stability factor for closed section should be 1.0. User can assign a member (column) which has horizontal load in the middle of it or not. Add prismatic section strength check. Update pipe section strength check. Merge Mx and My in one direction. Update double angle section check. Check the strength of flange and web individual. Support SSDD 2006 design parameter database. Section table Update section table support GB/T 11263 Update section table for SSDD. Read prismatic sections, compatible with Staad.Pro. Load combination Support Self weight "List" command. GUI Update 3D show for Prismatic section. Additional updates information can be found in the Revision History document.
Where I can download the SSDD software? I have a Staad Pro Connect Edition.
Thank you.
I see that you have created a service request as well; we will get back to you through it.
Thank you. I used to have the V8i and I remember using the SSDD, but now I cant find the version for Connect edition.
STAAD Chinese Steel Design Code has been released. I have sent you an email via service request.
