I recently tried the feature of generating the properties of a built-up section by using the "Tools / Create user table / Add new property" then checking the "Define Profile Polygon" and inputting the perimeter points. I was able to generate the cross-section and the properties, but when I look at the member in the model while rendering "Full Sections" or "Sections Outline", the member is shown offsetted from the local X axis defined by the Start and End joints. I was expecting to see the local X axis going through the CG of the cross section - Is there a way to make this happen?
I'm listing below the input of a simple model where the problem can be observed.
STAAD SPACEUNIT FEET KIPJOINT COORDINATES1 0 0 02 50 0 0MEMBER INCIDENCES1 1 2 START USER TABLETABLE 1GENERALTESTMEMB1.25 1.5 0 1 0 0.175694 0.09375 0.217853 0.202724 0.1875 1.00894 1.06914 -0.401111 0.291667 0.000966092 1.5PROFILE_POINTS -0.5 -0.633333 0.5 -0.633333 0.5 0.366667 0 0.866667 -0.5 0.366667ENDMEMBER PROPERTY1 UPTABLE 1 TESTMEMBSUPPORTS1 PINNEDFINISH
i am recently working on the nonlinear behavior of structures. so i need to locate the plastic hinge formation and the subsequent behavior after that. i also need to generate a graph (moment vs curvature)and find the load at which it leads to the rupture of the beam. and how am i supposed to do it in staad..
