Sir,
Kindly help how to make use of the EUDL and GLD parametesrs as given in the
Indian Codes - Concrete Design Per IS13920
8A1.5 Column Design.
I tried many means to input the same but failed. I need how to input the command and where it shuold appear in the Staad editor?
Thanks in advance.
regards,
Rangarajan.
Dear Sir,
I have given the details in another post of similar nature... I dont know how to use EUDL (seems too complicated). But GLD parameter is easy.
Usage of GLD parameter:
After setting Design Code as IS13920 and before setting Design beam command, enter
GLD <load comb no> <list of beams>
The load comb number should refer to a load combination in the staad file that has all dead and live loads and list of beams should be full set of beams being designed by IS13920 code...
Hope that helps...
Arun
Dear Mr.Arun,
Thanks for your reply. I went through the help menu and got the answers. You can use either EUDL or GLD. I f used both the program considers the EUDL. The EUDL value is to be calculated manualyy of DL and LL on member and enter as:
EUDL 30Member 10 12 where 30 is the DL +LL and 10 and 12 are the member number.
Just carefully go through the section IS13920 given in the manual where the statements of the commands are put in order.
Hope that the above may help and if any comments on this is welcome.
T.Rangarajan.
Yes, I think I understand EUDL command now... But I think it is too complicated to use EUDL command for each member/group of members in a large structure... And there will be chance for human error as the structure becomes larger and more complex... I feel GLD is the easy solution... Maybe EUDL can be used if unsupported commands like CMOM, etc are present in the load cases...
Arunkumar
While using GLD command , whether it is to be applied on all beams and columns or beams only..????
Also please suggest all the parameters to be selected while designing building as per IS 13920 along with their values to be considered.
