HELLO,
Is it possible to design the composite beam and composite column in staad ? if not then how do i design it in staad. with the help of macros or what?
A composite beam (I shaped beam with a slab on top) can be designed in STAAD per the AISC ASD (9th edition) and AISC LRFD (2nd and 3rd edition) codes. More information is available in sections 2.9 and 2.14.13 of the STAAD.Pro Technical Reference manual.
