warning
hello,
705 715 START FX FZ MX MY
705 715 END FX FZ MX MY   . these are the release specification given and one more think is that i my beam is incline.
  • Dear Chavada,
    You have not furnished the full particulars. What occurs to me with the little information that you have furnished that FX, FY and MX can not be released at both ends. The release that you have assigned is going to make the beam unstable. you remove all the above three releases from one end only. I feel the warning will not reappear. Please do and let me know thereafter if the warning still persists.
  • The warning indicates that a load is applied along a degree of freedom that has been released. For example, assume that you have released FX at both ends of a member. If the member has a slope, and selfweight is one of the loads, the load is bound to act along the axial degree of freedom. This will trigger the warning message.
    Another example is when you have released FY or FZ on a member and there is a load acting along the local Y or local Z directions.
Reply
