I want to convert "OPENSTAAD VBA" to "VB.NET (*. exe)".
"VISUAL_STUDIO2010" and "StaadPro V8i" are using.
Preparation of program development "OpenSTAAD 1.0 Type Library" and "OpenSTAADUI" referred to.
I can not convert [user dialog macro] to vb.net.
Example #
Begin Dialog UserDialog 590,490, "Rectangular Concrete Beam Parameters" '% GRID: 10,7,1,1
Text (10, 14, 120, 14, "Number of Layers",. Text1)
DropListBox (150, 14, 100, 56, LayerList (),. NoLayers)
End Dialog #
I hope this part teaches you how to convert VB.NET without using forms and text boxes.
Regards, Koji
Dear Koji
I have a problem regarding VB.Net. I have made one programe using VB6 for getting member force from staad. I used openstaad and got sucussesfully all the forces. Now, I making same programe in visual basic 2010. But I found problem to getting forces in force array. I used same sentance i.e (objOpenSTAAD.GetIntermediateMemberForcesAtDistance(Column, Dist, LC, Force(0)) in my new programe.
Please help me.There is a any compatibily problem within Openstaad?
My VB.net code is as below.
Public Class Form1
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim Column As Long
Dim LC As Long
Dim TxtF_Path As String
'Dim objOpenSTAAD
Dim objOpenSTAAD As Object
Dim Dist As Double
Dim Ctr As Integer
Dim Force(0 To 5) As Double
'objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
objOpenSTAAD = CreateObject("OpenSTAAD.Output.1")
TxtF_Path = "D:\VB\Working\Column Design\STAAD\RW\P11_14_1_CHLORINATION SYSTEM_R2.std"
objOpenSTAAD.selectSTAADFile(TxtF_Path)
Column = 510
LC = 7
For Dist = 0 To 1 Step 0.25
'objOpenSTAAD.output.GetIntermediateMemberForcesAtDistance(Column, Dist, LC, Force(0))
For Ctr = 0 To 2 Step 1
Math.Round((Force(Ctr) * 4.44822), 3)
'Math.Round((Force(1) * 4.44822), 3)
'Math.Round((Force(2) * 4.44822), 3)
Next Ctr
'For ctr = 0 To 5 Step 1
' MsgBox("Fx = " & Math.Round((Force(ctr) * 4.44822), 3))
'MsgBox("Mx = " & Math.Round((Force(1) * 4.44822), 3))
'Next ctr
Next Dist
objOpenSTAAD.CloseSTAADFile()
objOpenSTAAD = Nothing
'Dim A As Double
'Dim B As Double
'A = 50
'B = 25
'MsgBox(" Maximum Value = " & Math.Max(A, B))
'MsgBox(" Minmum Value = " & Math.Min(A, B))
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
End Class
