Hi, can someone give some guidance to a new STAAD user as to how to do a proper deflection check for beams for a structure?
Ive tried to use the DFF command for a STAAD model im working on now but am unable to see any tangible results. After reading the forum posts I could find, it seems that DFF can only be checked by actually going through the STAAD PRO output file manually and will not be displayed in the post processing results, am I correct?
My problem is that I do not know what I am looking for. (As in what a DFF failure would look like) I am unable to find any indication in the post processing tab of any failure in my model. My model passes for design.
However I know that my model would fail a DFF check as using the post processing page, I have observed that there is a beam in the model with a dff of 114.4. The DFF value for the analysis is set to 360.
I calculated the dff manually by using, span length = 1258.5 & resultant beam deflection = 11. dff =1258.5/11=114.4
Can someone please advise me if my understanding if correct? And if so, how to check dff results for an analysis.
Dave
DFF command is available only for steel design. Please let me know as to whether you have put in DFF command in the file and also put in the value and assigned the same to the member for which you are looking for the DFF result. If the command is not assigned to the member for which the DFF is working out to 114.4, the Staad will not take cognizance of the input DFF for the member. . Please also check whether there is any node between the support of the beam in question. . Please check and post.
The steel design output can also be viewed in a report. After the analysis, choose File-Report Setup. In the drop down list for Available, choose Output. Select Steel Design Detail followed by OK. Go back to the File menu and choose Print Preview Report. The deflection check results will be part of the design output. The value calculated as L/d is reported using lowercase "dff". Attached is the screen grab of a sample.
Hi all! Thanks for the advice! Well Im finally able to see the dff results but it seems my dff results are all 0. I am not sure what but I am guessing that it is because ive done a deflection check on beams that are not in between supports am I correct?
If that is incorrect, please correct me and also advise me how I may perform a deflection check for a model of this kind.
STAAD output follows in trailing posts
STAAD SPACE
START JOB INFORMATION
JOB COMMENT Geometry- NA
JOB COMMENT Specifications-NA
JOB COMMENT Joint Modeling-NA
JOB COMMENT Supports-OK
END JOB INFORMATION
INPUT WIDTH 79
UNIT MMS NEWTON
JOINT COORDINATES
1 0 0 0; 2 7832 0 0; 3 3916 0 0; 4 0 0 2830; 5 7832 0 2830; 6 3916 0 2830;
7 0 2734.5 0; 8 7832 2734.5 0; 9 3916 2734.5 0; 10 0 2734.5 2830;
11 7832 2734.5 2830; 12 3916 2734.5 2830; 13 0 2343 0; 14 7832 2343 0;
15 0 2343 2830; 16 7832 2343 2830; 17 -1637 2343 0; 18 -1637 2343 2830;
19 9469 2343 0; 20 9469 2343 2830; 21 -804 2343 0; 22 -804 2343 2830;
23 8636 2343 0; 24 8636 2343 2830; 25 -1637 2343 1880; 26 9469 2343 1880;
27 -804 2343 1880; 28 8636 2343 1880; 29 -1637 2343 950; 30 9469 2343 950;
31 -804 2343 950; 32 8636 2343 950; 33 -1330 2343 0; 34 -1330 2343 2830;
35 9162 2343 0; 36 9162 2343 2830; 37 0 1013 0; 38 7832 1013 0; 39 0 1013 2830;
40 7832 1013 2830; 41 0 493 2830; 42 7832 493 2830; 45 -1485 493 2830;
46 9317 493 2830; 47 2183.5 2734.5 0; 48 5648.5 2734.5 0;
49 5648.5 2734.5 2830; 50 2183.5 2734.5 2830; 51 1408.5 2734.5 0;
52 6423.5 2734.5 0; 53 6423.5 2734.5 2830; 54 1408.5 2734.5 2830;
55 2183.5 1956 0; 56 5648.5 1956 0; 57 5648.5 1956 2830; 58 2183.5 1956 2830;
59 1408.5 1956 0; 60 6423.5 1956 0; 61 6423.5 1956 2830; 62 1408.5 1956 2830;
63 1408.5 1956 1415; 64 2183.5 1956 1415; 65 5648.5 1956 1415;
66 6423.5 1956 1415; 67 1408.5 1956 156.5; 68 2183.5 1956 156.5;
69 5648.5 1956 156.5; 70 6423.5 1956 156.5; 71 1408.5 1956 2673.5;
72 2183.5 1956 2673.5; 73 5648.5 1956 2673.5; 74 6423.5 1956 2673.5;
75 0 2734.5 1415; 76 7832 2734.5 1415; 77 1050 2734.5 0; 78 6782 2734.5 0;
79 6782 2734.5 2830; 80 1050 2734.5 2830; 81 2866 2734.5 0; 82 4966 2734.5 0;
83 4966 2734.5 2830; 84 2866 2734.5 2830; 85 0 450 0; 86 7832 450 0;
87 3916 450 0; 88 3916 450 2830; 89 0 450 2830; 90 7832 450 2830;
91 0 2964.5 0; 92 7832 2964.5 0; 93 3916 2964.5 0; 94 0 2964.5 2830;
95 7832 2964.5 2830; 96 3916 2964.5 2830;
MEMBER INCIDENCES
1 1 85; 2 2 86; 3 3 87; 4 4 89; 5 5 90; 6 6 88; 7 7 77; 8 8 78; 9 11 79;
10 10 80; 11 7 75; 12 8 76; 13 9 12; 14 13 7; 15 14 8; 16 15 10; 17 16 11;
18 13 21; 19 15 22; 22 17 29; 23 19 30; 24 21 33; 25 22 34; 26 23 35; 27 24 36;
28 21 31; 29 23 32; 30 25 18; 31 26 20; 32 27 22; 33 28 24; 34 29 25; 35 30 26;
36 31 27; 37 32 28; 38 31 29; 39 27 25; 40 32 30; 41 28 26; 42 33 17; 43 34 18;
44 35 19; 45 36 20; 46 37 13; 47 38 14; 48 39 15; 49 40 16; 50 39 34; 51 37 33;
52 40 36; 53 38 35; 54 41 39; 55 42 40; 60 41 45; 61 42 46; 62 47 81; 63 48 82;
64 49 83; 65 50 84; 66 51 47; 67 52 48; 68 53 49; 69 54 50; 70 47 55; 71 48 56;
72 49 57; 73 50 58; 74 51 59; 75 52 60; 76 53 61; 77 54 62; 78 59 67; 79 55 68;
80 56 69; 81 60 70; 82 63 71; 83 64 72; 86 63 64; 87 65 66; 88 67 63; 89 68 64;
90 69 65; 91 70 66; 92 71 62; 93 72 58; 94 73 57; 95 74 61; 96 67 68; 97 71 72;
98 69 70; 99 73 74; 102 85 75; 103 89 75; 104 86 76; 105 90 76; 106 77 51;
107 78 52; 108 79 53; 109 80 54; 110 81 9; 111 82 9; 112 83 12; 113 84 12;
114 80 89; 115 84 88; 116 83 88; 117 81 87; 118 82 87; 119 77 85; 120 79 90;
121 78 86; 122 16 24; 123 14 23; 124 11 76; 125 10 75; 126 85 37; 127 86 38;
128 87 9; 129 88 12; 130 89 41; 131 90 42; 132 7 91; 133 8 92; 134 9 93;
135 10 94; 136 11 95; 137 12 96; 138 73 65; 139 74 66;
START GROUP DEFINITION
MEMBER
FLOOR
_FIXD_PLAT 22 24 25 28 30 32 34 36 38 39 42 43
_FLOT_PLAT 23 26 27 29 31 33 35 37 40 41 44 45
END GROUP DEFINITION
START USER TABLE
TABLE 1
CHANNEL
PLENUM
3588 460 6 75 6 9.13365e+007 1.23246e+006 43056 11.6538 2760 600
MOTFRAME
2628 300 6 75 6 3.13947e+007 1.13143e+006 31536 14.8151 1800 600
PLENUMT
4752 460 8 75 8 1.1965e+008 1.58807e+006 101376 12.4596 3680 800
TABLE 2
WIDE FLANGE
MIDBEAM
4488 460 6 150 6 1.37715e+008 3.38306e+006 53856 2760 1200
END
DEFINE MATERIAL START
ISOTROPIC STEEL
E 205000
POISSON 0.3
DENSITY 7.68195e-005
ALPHA 1.2e-005
DAMP 0.03
END DEFINE MATERIAL
MEMBER PROPERTY CHINESE
18 19 22 TO 45 60 61 122 123 TABLE ST CH16B
MEMBER PROPERTY JAPANESE
50 TO 53 70 TO 77 102 TO 105 114 TO 121 TABLE ST L75X75X9
1 TO 6 14 TO 17 46 TO 49 54 55 126 TO 137 TABLE ST HW150X150
78 TO 83 86 TO 99 138 139 UPTABLE 1 MOTFRAME
13 UPTABLE 2 MIDBEAM
7 TO 12 62 TO 69 106 TO 113 124 125 UPTABLE 1 PLENUMT
CONSTANTS
BETA 180 MEMB 7 9 12 18 22 24 27 29 30 33 34 37 38 41 42 45 61 62 64 66 68 -
79 81 83 89 91 93 95 96 98 106 108 110 112 122 125 138
BETA 315 MEMB 50 53 73 76 103 104 114 116 117 121
BETA 45 MEMB 51 52 70 75 102 105 115 118 TO 120
BETA 90 MEMB 1 TO 6 14 TO 17 46 TO 49 54 55 86 87 126 TO 137
BETA 135 MEMB 71 74
BETA 225 MEMB 72 77
MATERIAL STEEL MEMB 1 TO 19 22 TO 55 60 TO 83 86 TO 99 102 TO 139
MEMBER OFFSET
18 19 50 51 60 START -75 0 0
52 53 61 122 123 START 75 0 0
70 TO 77 114 TO 121 START 0 -230 0
50 TO 53 END 0 -80 0
114 116 118 119 END 75 0 0
115 117 120 121 END -75 0 0
103 105 END 0 -230 150
102 104 END 0 -230 -150
102 104 START 0 0 75
103 105 START 0 0 -75
70 TO 77 END 0 -150 0
79 81 83 89 91 93 95 139 START 50 0 0
79 81 83 89 91 93 95 139 END 50 0 0
78 80 82 88 90 92 94 138 START -50 0 0
78 80 82 88 90 92 94 138 END -50 0 0
86 87 96 TO 99 START -37.5 0 0
86 87 96 TO 99 END 37.5 0 0
SUPPORTS
1 TO 6 FIXED
MEMBER TRUSS
50 TO 53 102 TO 105 114 TO 121
DEFINE WIND LOAD
TYPE 1
INT 0.00128452 0.00128452 0.00128983 0.00129505 0.00130016 0.00130518 -
0.00131011 0.00131496 0.00131972 0.0013244 0.001329 0.00133353 0.00133799 -
0.00134238 0.0013467 HEIG 0 4572 4681.85 4791.69 4901.54 5011.38 -
5121.23 5231.08 5340.92 5450.77 5560.62 5670.46 5780.31 5890.15 6000
EXP 1 JOINT 1 TO 42 45 TO 96
TYPE 2
INT 0.00119521 0.00119521 0.00120016 0.00120501 0.00120977 0.00121444 -
0.00121903 0.00122354 0.00122797 0.00123232 0.00123661 0.00124082 0.00124497 -
0.00124905 0.00125307 HEIG 0 4572 4681.85 4791.69 4901.54 5011.38 -
LOAD 1 LOADTYPE None TITLE SELFWEIGHT
SELFWEIGHT Y -1
LOAD 2 LOADTYPE None TITLE LOAD 1
MEMBER LOAD
7 TO 10 62 TO 69 106 TO 113 UNI GY -4.14
LOAD 3 LOADTYPE None TITLE LOAD 2
JOINT LOAD
91 94 FY -15880
LOAD 4 LOADTYPE None TITLE LOAD 3
7 TO 10 62 TO 69 106 TO 113 UNI GY -0.47
91 92 94 95 FY -637.65
LOAD 5 LOADTYPE None TITLE LOAD 5
FLOOR LOAD
_FIXD_PLAT FLOAD -0.005 GY
_FLOT_PLAT FLOAD -0.005 GY
LOAD 6 LOADTYPE None TITLE LOAD 6
86 87 CON GY -770 425
LOAD 7 LOADTYPE None TITLE LOAD 7
86 87 CON GY -1300 425
LOAD 8 LOADTYPE None TITLE LOAD 8
86 87 CON GY -490.5 425
LOAD 9 LOADTYPE None TITLE LOAD 9
88 89 138 139 CON GY -2207.5 560
LOAD 10 LOADTYPE None TITLE LOAD 10
86 CON GZ -2061 425
87 CON GZ 2061 425
LOAD 11 LOADTYPE None TITLE LOAD 11
7 TO 10 62 TO 69 106 TO 113 UNI GY -0.828
86 87 CON GY -154 425
86 87 CON GY -260 425
86 87 CON GY -98.1 425
88 89 138 139 CON GY -442 560
86 CON GZ -415 425
87 CON GZ 415 425
LOAD 12 LOADTYPE None TITLE LOAD 12
LOAD 13 LOADTYPE None TITLE LOAD 13
7 TO 10 62 TO 69 106 TO 113 UNI GX 0.828
86 87 CON GX 154 425
86 87 CON GX 98.1 425
88 89 138 139 CON GX 442 560
LOAD 14 LOADTYPE None TITLE LOAD 14
7 TO 10 62 TO 69 106 TO 113 UNI GZ 0.828
86 87 CON GZ 154 425
86 87 CON GZ 98.1 425
88 89 138 139 CON GZ 442 560
LOAD 15 LOADTYPE None TITLE LOAD 15
WIND LOAD X 1 TYPE 1 XR -2000 0 YR 0 6000 ZR 0 4000 OPEN
LOAD 16 LOADTYPE None TITLE LOAD 16
WIND LOAD Z 1 TYPE 2 XR -2000 10000 YR 0 6000 ZR -50 100 OPEN
LOAD COMB 18 LOAD 17
1 1.0 2 1.0 3 1.0 5 1.0 6 1.0 7 1.0 8 1.0 9 1.0 10 1.0 11 1.0 15 1.0 -
16 1.0
LOAD COMB 19 LOAD 18
1 1.0 2 1.0 3 1.0 4 1.0 5 1.0 15 1.0 16 1.0 6 1.0 8 1.0 9 1.0 10 1.0
LOAD COMB 20 LOAD 19
1 1.0 2 1.0 6 1.0 5 1.0 8 1.0 9 1.0 10 1.0 12 1.0 13 1.0 14 1.0 15 1.0 -
16 1.0 3 1.0
PERFORM ANALYSIS
CHECK CODE ALL
PARAMETER
CODE AISC
DFF 360 MEMB 1 TO 19 22 TO 49 54 55 60 TO 83 86 TO 99 106 TO 113 122 TO 139
DJ1 60 MEMB 81 91 95 139
DJ2 61 MEMB 81 91 95 139
DJ1 56 MEMB 80 90 94 138
DJ2 57 MEMB 80 90 94 138
DJ1 55 MEMB 79 83 89 93
DJ2 58 MEMB 79 83 89 93
DJ1 59 MEMB 78 82 88 92
DJ1 62 MEMB 78 82 88 92
DJ1 7 MEMB 11 125
DJ2 10 MEMB 11 125
DJ1 8 MEMB 12 124
DJ2 11 MEMB 12 124
DJ1 10 MEMB 10 65 69 109 113
DJ2 12 MEMB 10 65 69 109 113
DJ1 11 MEMB 9 64 68 108 112
DJ2 12 MEMB 9 64 68 108 112
DJ1 7 MEMB 7 62 66 106 110
DJ2 9 MEMB 7 62 66 106 110
DJ1 8 MEMB 8 63 67 107 111
DJ2 9 MEMB 8 63 67 107 111
DJ1 21 MEMB 28 32 36
DJ2 22 MEMB 28 32 36
DJ1 17 MEMB 22 30 34
DJ2 18 MEMB 22 30 34
DJ1 23 MEMB 29 33 37
DJ2 24 MEMB 29 33 37
DJ1 19 MEMB 23 31 35
DJ2 20 MEMB 23 31 35
DJ1 19 MEMB 26 44 123
DJ2 14 MEMB 26 44 123
DJ1 16 MEMB 27 45 122
DJ2 20 MEMB 27 45 122
DJ1 15 MEMB 19 25 43
DJ2 18 MEMB 19 25 43
DJ1 13 MEMB 18 24 42
DJ2 17 MEMB 18 24 42
CAN 1 MEMB 60 61
FINISH
