Split Walls in RAM SS
Is there a simple way to split walls in RAM SS?
I keep getting the following error:
"Wall #XX has another Wall framing into its interior on Layout Type XXXXX.
Wall coordinates ( ft ) (XX.XXXX,XX.XXXX), (XX.XXXX,XX.XXXX)
Frame-in Wall coordinates ( ft ) (XX.XXXX,XX.XXXX), (XX.XXXX,XX.XXXX)
User Action: Split wall into separate elements wherever this occurs"
Happens whenever I draw in a new wall and have it frame into another wall between its ends. Goes away once I delete the wall being framed in to and redraw as two walls with ends at the intersection of the wall framing in and the previous walls.
Is there an easier way to split a wall once it's drawn, instead of just deleting and redrawing as two walls?
Or another way to get this error to stop happening? Maybe have drawn in walls snap to wall faces rather than centers?
Thanks.
Parents Reply Children
