Does the RAM Connection in STAAD is not designing a baseplate? there is a option but still it is not assigning in the column base.
However, baseplate with gusset connection works fine.
Using the geometry selection tool select both the support node and the column that is attached to it. Does that fix it?
Great! You are right. But how can I rotate the extruded view. There is no icon or menu to control it.
Thanks!
Hover over the graphic, hold down the right mouse button, move the mouse. Voila!
OK. I didn't thought that thr irght click will works. Thanks!
