Staad Error Message:
hello folks,
When i run the staad file that i have attached in this post, i get an error message.
"above line contains erroneous data"
Can any gurus plz help me out with this model.
> Is the error due to the application of floor load on inclined members??? (grouped members)
any tips will be valuable.
regards
REV4_Godola+500kg.std
  • I see 2 problems.
    The first problem may or may not be present in your version depending on what you are running. Nevertheless, here is the solution to both.
    Problem 1 : Program not identifying a tube named TUB120603.65. The solution is:
    Start the program from its Program Group (instead of double clicking on the STAAD file).
    On the opening screen of the program, in the group of buttons titled "Project Tasks", choose Configuration. The "Configure Program dialog" will come up. Choose the tab titled Section Profile Table. In the row titled Indian, click on the right cell. A down arrow ill appear. You will see 2 items - IndianSections and IndianLegacySections. Choose the latter. Click on Accept.
    Next try opening the STAAD file.
    Problem 2 : Program stops with the message "Above Line contains erroneous data. The solution is:
    Your load case is specified in the following manner:
    UNIT CM KG
    LOAD 1 LOADTYPE Dead  TITLE DL
    SELFWEIGHT Y -1
    START GROUP DEFINITION
    FLOOR
    _FR1BMS 116 TO 121 131 TO 137 145 TO 150
    _FR2BMS 57 TO 64 89 91 93 99 TO 102 110 TO 112 116 TO 121
    END GROUP DEFINITION
    UNIT MMS NEWTON
    FLOOR LOAD
    YRANGE 0 0 FLOAD -0.0001 XRANGE 3325 5494  ZRANGE -4000 4000  GY
    Righ in the midst of load case 1, you have a group definition. Re-arrange the order of those lines to
    UNIT CM KG
    FLOOR
    UNIT MMS NEWTON
    SELFWEIGHT Y -1
    FLOOR LOAD
    With these changes, the file runs. But there are a number of warnings stating that the FLOOR LOAD isn't getting generated. Check the XRANGEs and ZRANGEs. I checked a few and found that the panels within these ranges are not closed boundaries.
    You also need to check the units of the Young's Modulus (E) in the Material data. There is a warning mentioning that
    A STIFF MATERIAL WITH  7.208E+01 TIMES THE STIFFNESS OF STEEL ENTERED.
Reply
  • I see 2 problems.
    UNIT CM KG
    SELFWEIGHT Y -1
    FLOOR
    UNIT MMS NEWTON
    FLOOR LOAD
    UNIT CM KG
    FLOOR
    UNIT MMS NEWTON
    SELFWEIGHT Y -1
    FLOOR LOAD
