STAAD.Pro 2007 Build 03 Available July 11
Build 03 of STAAD.Pro 2007 will be available on Bentley SELECT servers tomorrow, July 11. This update includes 22 new features and 115 additional updates. See here for some more info on some of these new features.
  • I found errors with the new mesh options , when I add a hole using anyone ( standar or basic ) method. The program does not run.
  • We acknowledge the error. We have already brought this to the attention of the development team. For the time being here are the workarounds. We would also like to mention that this happens only when you try to insert hole during parametric meshing option. if you try to add the hole after meshing it doesnt cause any errors
    1. In your STAAD model, go to Edit> Edit Input command file
    2. In the input file, you will find the following commands.
    PARAMETRIC MODEL MESH MODEL 3
    MESH PARAM 0.7 4 0 0
    MESH ORG 1 2 3
    BOUNDARY 5
    DENSITY LINE 0 0 2.8 1 2.7 0 2.8 1 0
    GENERATED NODES 10 TO 1042
    GENERATED PLATES ALL
    END
    These commands are meant for Parametric modeling. The main function of these commands are to generate the plates. Since, the plates has been successfully generated, we can inactivate the list of commands by putting a asterix mark before the lines as shown below.
    *PARAMETRIC MODEL MESH MODEL 3
    *MESH PARAM 0.7 4 0 0
    *MESH ORG 1 2 3
    *BOUNDARY 5
    *DENSITY LINE 0 0 2.8 1 2.7 0 2.8 1 0
    *GENERATED NODES 10 TO 1042
    *GENERATED PLATES ALL
    *END
    Generally, the parametric modeling data need to be generated in the following way.
    <! STAAD PRO GENERATED DATA DO NOT MODIFY!!!
    PARAMETRIC MODELING COMMANDS
    !> END GENERATED DATA BLOCK
    The reason why you are getting the error message during analysis is because these comment lines (i.e.
    So, as a alternative process you can add these commands from the STAAD editor.
    <!STAAD PRO GENERATED DATA DO NOT MODIFY
    MESH ORG 1 2 3
    BOUNDARY 5
    END
  • Thanks Nihesh
    I have a new problem, it hapens when I try to input the load case in a Front to Front or Back to back channel , the program display an error for the both cases.
  • Can you attach the STAAD file or send it to my email address nihesh.n@bentley.com?
  • Sorry It was an error on my system
    Kind Regards
