Shear Wall Building
Dear All, I am designing a RCC 7 Storey apartment building in which all the slabs are supported on shear walls only using staad pro. There are no columns and beams. Can any one upload a input file of similar building based on Indian codes codes.
My approach is 1) Generate concrete surfaces & shear walls & assign parameters
2) Mass modeling by considering all the joint as hinge
3)applying Load Combination (DL+ .75LL) to get joint weights
4) Applying IS 1893 load Seismic in X -Direction sesimic in Z Direction 5)Applying joint weights
6) Applying floor load
7) Element Loads
8) Perform Analysis
9) Start concrete Design Units Newton MM Design Shear Wall End Concrete Design Finish Is my approach correct?????? How to extract reinforcement??????? Thanks in Advance??????? regards,
Atul
atulkumarengineer@gmail.com
Parents Reply Children
