When running the STAAD, the result shows everything is right,. Structure is stable, no warning. Displacements are limited. BUT, I get some funny numbers for rotational displacement e.g. 533 degree & sometimes more.
I checked releases. I believe they are correct.
any body can help me out kindly ??
I attached the file ............ Please kindly review. Thank you
Hajir
I tried my best to locate the abnormally high rotation in the post processing. I did not get. Will you please state as to for which load case and node no. you are getting high rotational displacement? I got normal output.
Load case 3, node # 14 >> rY 354 deg
Load case 205, node # 88
Load case 175, node # 168
there are more examples
The file that you have posted has max 74 nodes and numbered 74. Hence there is no question of node no.88 and 168. You might be seeing something else in output file.
really sorry ...........I am working on two models at the same time.
here are correct numbers:
Laod case 3 >> node 28, rY 293 deg
& node 20, rY 288 deg
Load case 175 >> node 28
Lad case 173 >> node 10
