Is there a way in STAAD to merge specifications, similar to what Merge Properties on the Tools menu does?For example if I have a big model and I finish assigning the End and Start Releases. On my specification window I only have 2 lines one for the end release and one for the start release.
Now if I save and close the program and then open it, the 2 Specifications will be split into 4 or 5 each so I end up with 4 or 5 End Releases and 4 of 5 Start Releases. Now if I continue to assign releases with any of the 5 specification lines that showed up, and do the same process of saving, closing and opening the model it will again keep splitting the lines. So I may end up with 10 End Releases and 10 Start Releases that do the same thing but are assign to different members.
So I would like to merge them back to only 1 End Release and 1 Start Release. Any sugestions?
Here are examples of these options
Write Commands in Single Line Format ---> Off
MEMBER INCIDENCES
1 1 3; 2 3 7; 3 2 6; 4 6 8; 5 3 4; 6 4 5; 7 5 6; 8 7 12; 9 12 14;
Write Commands in Single Line Format ---> On
1 1 3
2 3 7
3 2 6
4 6 8
5 3 4
6 4 5
7 5 6
8 7 12
9 12 14
Write Expanded List ---> Off
MEMBER PROPERTY AMERICAN
1 3 4 TABLE ST W14X90
Write Expanded List ---> On
1 TABLE ST W14X90
3 TABLE ST W14X90
4 TABLE ST W14X90
In the Tools menu, there is a "Merge Properties" tool if the same property name is assigned for different sets of members.
I suppose if you use a combination of the manual method proposed by Arunkumar, and, keep the "Write Commands in Single Line Format" as well as "Write Expanded List" in the Off setting, the problem shouldn't recur.
Thanks for the info, that's good to know. I played around with it a little bit and found that once you turn on "Write Expanded List" and then save the file, turning it back off does not restore the file like it was. Only subsequent entries are back to nonexpanded list.
