I was wondering if there is any literature on the best way to approach the design of a simple four sided moment frame building using RAM Structural System?
Scott
Right, when the design is controlled by something in the Frame module (e.g. drift or steel provisions) then the user has to manually change the size (using View/Update or Assign – Size) until everything works. “Optimizing” lateral members is tricky for a number of reasons. Take a simple moment frame example. Given a certain size for the beam and columns you get a certain distribution of forces. If you then select a member size that has the strength to resist those forces then you change the force distribution, not to mention the self-weight, so another analysis is required and another optimization and so forth.
We could add an iterative member optimizer to handle such a thing, and we probably should (I’m sure that’s already on the enhancement list somewhere), but when you add optimization for drift, seismic provisions, and joint checks that could get overwhelming.
