I need help, I am trying to get a moving load to go from one node to another.
For example, if I have nodes N1, N2 and N3, and member M1 runs from N1 to N2, while member M2 runs from N2 to N3. How do I get a moving load to move from member M1 through M2, going from the first node to the last node?
Note: The beam orientation is not on any of the global axis, and therefore I dont think I can use the incrememnt option in the load generation menu, since it only increases it in the global axis.
You'll have to use XINCREMENT, ZINCREMENT and YRANGE in a single instruction.
TYPE 1 0 0. 0. XINC 1 ZINC 1. YRA 6
Attached is an example.
