I've made the slab base (with the required thickness), attached it to the roof slab with 4 columns.. i've manually calculated all the loadings possible, and assigned them to the roof slab (as a floor load), and the self weight for all members.. but i get an error which says the structure is unstable.... please give me ur suggestions on how to move about with the model..
thanks in advance
