Staad steel design EC3 code checking
Hi
I am performing a code check against EC3 and have specified the TRACK parameter as 2.0 i.e. to output detailed results. I see these results in the output file but there does not seem to be any way to include them in a report. If I select Steel Design Detail from the Output item categories, only very basic results as per TRACK 0.0 are displayed in the report (even though ‘Track 2’ is shown in the title for each member.) Is there any way to include the TRACK 2 results in a report or have I missed something?
Incidentally, if I perform a code check using the steel design module (post-processing) then I can select steel design output from the item categories and include a detailed design calculation for each (physical) member in the report, but I can only check against the old (EC3 DD ENV 1993-1-1:1992) Eurocode; this has been superseded by EC3 BS EN 1993-1-1:2005 which must be checked by the batch design method. What is the reason for this? To my mind the steel design module is preferable as it is possible to specify and check physical members made up of several beams and also to specify varying load cases / groups to be checked, and without re-running the analysis (as well as include each calculation in a report.)
Any advice / solutions would be much appreciated.
Edward
Parents Reply Children
