Why Unable to apply Wind load for cooling tower kind of structure. i.e Structure with only plates or surfaces.
Error Shows :
**ERROR NO MEMBERS IN RANGE IN WIND LOAD.
Practically there won't be beams or column members in such a structure.
Is there any other way to apply wind load for this type of structures.
Hello
Apply the load as Element Pressure Load
Thanks for quick replay.
I have not applied as member load.
I defined wind load in Wind defination and assigned to the structure.
But it is not applied.
Is wind load defination is only applicable for members?
-Vivek
Hi Vivek
Automatic Wind Load generation in STAAD cannot generate wind loading on plates. The wind load can only be generated on closed panels bounded by members . Kindly refer article 5.31.3 of the Technical Reference Manual .
The drives Amarillo Gear Company produces for cooling tower and air fin heat exchanger service reflect a long history of quality workmanship and reliability. The soft water or other liquid circulates in the cooling coil, where the heat transfer happens via coil surface and the hot air is dispelled out. Amarillo Gear Company serves customers worldwide. The company was founded and is based in Amarillo. Amarillo Gear Company LLC manufactures spiral bevel right angle gear drives for agricultural irrigation applications. As the Amarillo authorised UK Service provider, Amarillo can ensure that they will get good Service coverage in the UK market. For more than 50 years, Allen Gears has gained extensive knowledge of gear technology through new gearbox design and manufacture. Amarillo Gear Company offers housings and castings, spiral bevel gears, bearings, shaft Cooling Tower seals, composite drive shafts. We can provide either composite or steel cooling tower drive shaft, no matter what the type of your existing drive shaft is. Based on the leading technology, Coolway design and manufacture cooling towers according to international standard. Series is a traditional fan forced draught closed circuit cooling tower, with inherently low noise centrifugal fans.
can you explain in detail sir.
