how to deal with the the problem of "badly shaped, not convex, warped,or not mumbered counter-clockwise"?
hello everyone,
anybody can help me to work out the issue, which showing the following warning after running analysis.
 *WARNING* PLATE NO.     4(JOINTS     51 -     53 -     52 -     50)
IS BADLY SHAPED, WARPED, NOT CONVEX, OR NOT NUMBERED COUNTER-CLOCKWISE.
thanks in advance.
regards,
kazeem.
  • It appears to me that all the 4 nodes are not in one plane. That may be checked with the joint coordinate. one coordinate (x or y or z) for all the 4 points has to be the same. Pl check.
  • thank you very much for your reply,
    now l'm doing a design of tank roof in steel structure, but actually, l can not solve this issue, would you mind to check the model shown as bellow, thanks a lot.
    STAAD SPACE
    START JOB INFORMATION
    ENGINEER DATE 29-May-12
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    1 -5.52 0 -3.62512e-008; 2 -5.24983 0 -1.70577; 3 -5.24983 0 1.70577;
    4 -4.46577 0 -3.24457; 5 -4.46577 0 3.24457; 6 -3.24457 0 -4.46577;
    7 -3.24457 0 4.46577; 8 -1.70577 0 -5.24983; 9 -1.70577 0 5.24983;
    10 -0.552 0.82 -8.73063e-009; 11 -0.524983 0.82 -0.170577;
    12 -0.524983 0.82 0.170577; 13 -0.446577 0.82 -0.324457;
    14 -0.446577 0.82 0.324457; 15 -0.324457 0.82 -0.446577;
    16 -0.324457 0.82 0.446577; 17 -0.170577 0.82 -0.524983;
    18 -0.170577 0.82 0.524983; 19 3.37991e-017 0.82 0.552; 20 3.37991e-016 0 5.52;
    21 8.73063e-009 0.82 -0.552; 22 3.62512e-008 0 -5.52;
    23 0.170577 0.82 0.524983; 24 0.170577 0.82 -0.524983;
    25 0.324457 0.82 0.446577; 26 0.324457 0.82 -0.446577;
    27 0.446577 0.82 0.324457; 28 0.446577 0.82 -0.324457;
    29 0.524983 0.82 0.170577; 30 0.524983 0.82 -0.170577;
    31 0.552 0.82 8.73063e-009; 32 1.70577 0 5.24983; 33 1.70577 0 -5.24983;
    34 3.24457 0 4.46577; 35 3.24457 0 -4.46577; 36 4.46577 0 3.24457;
    37 4.46577 0 -3.24457; 38 5.24983 0 1.70577; 39 5.24983 0 -1.70577;
    40 5.52 0 3.62512e-008;
    MEMBER INCIDENCES
    1 20 19; 3 32 23; 64 19 23; 67 34 25; 68 23 25; 72 36 27; 73 25 27; 77 38 29;
    78 27 29; 82 40 31; 83 29 31; 87 39 30; 88 31 30; 92 37 28; 93 30 28; 97 35 26;
    98 28 26; 102 33 24; 103 26 24; 107 22 21; 108 24 21; 112 8 17; 113 21 17;
    117 6 15; 118 17 15; 122 4 13; 123 15 13; 127 2 11; 128 13 11; 132 1 10;
    133 11 10; 137 3 12; 138 10 12; 142 5 14; 143 12 14; 147 7 16; 148 14 16;
    152 9 18; 153 16 18; 157 18 19;
    ELEMENT INCIDENCES SHELL
    2 11 10 1 2; 4 10 12 3 1; 5 13 11 2 4; 6 12 14 5 3; 7 15 13 4 6; 8 14 16 7 5;
    9 17 15 6 8; 10 16 18 9 7; 11 18 19 20 9; 12 21 17 8 22; 13 19 23 32 20;
    14 24 21 22 33; 15 23 25 34 32; 16 26 24 33 35; 17 25 27 36 34; 18 28 26 35 37;
    19 27 29 38 36; 20 30 28 37 39; 21 29 31 40 38; 22 31 30 39 40;
    ELEMENT PROPERTY
    2 4 TO 22 THICKNESS 0.007
    DEFINE MATERIAL START
    ISOTROPIC STEEL
    E 2.05e+008
    POISSON 0.3
    DENSITY 76.8195
    ALPHA 1.2e-005
    DAMP 0.03
    TYPE STEEL
    STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2
    ISOTROPIC CONCRETE
    E 2.17185e+007
    POISSON 0.17
    DENSITY 23.5616
    ALPHA 1e-005
    DAMP 0.05
    TYPE CONCRETE
    STRENGTH FCU 27579
    END DEFINE MATERIAL
    MEMBER PROPERTY EUROPEAN
    1 3 67 72 77 82 87 92 97 102 107 112 117 122 127 132 137 142 147 -
    152 TABLE ST UPN200
    64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 143 148 153 -
    157 TABLE ST UPN300
    CONSTANTS
    MATERIAL STEEL MEMB 1 3 64 67 68 72 73 77 78 82 83 87 88 92 93 97 98 102 103 -
    107 108 112 113 117 118 122 123 127 128 132 133 137 138 142 143 147 148 152 -
    153 157
    MATERIAL CONCRETE MEMB 2 4 TO 22
    SUPPORTS
    1 TO 9 20 22 32 TO 40 PINNED
    MEMBER RELEASE
    152 START MX MY MZ
    152 END MX MY MZ
    DEFINE MOVING LOAD
    TYPE 1 HS15 1 1
    LOAD 1 LOADTYPE Dead  TITLE DL
    SELFWEIGHT Y -1
    LOAD 2 LOADTYPE Live REDUCIBLE TITLE LL
    MEMBER LOAD
    1 3 67 72 82 87 92 97 102 107 112 117 122 127 132 137 142 147 -
    152 TRAP GY -1.5 0
    LOAD 3 LOADTYPE Wind  TITLE WL
    ELEMENT LOAD
    2 4 TO 22 PR GY -1
    LOAD COMB 4 COMBINATION LOAD CASE 4
    1 1.0 2 1.0 3 1.0
    PERFORM ANALYSIS
    PARAMETER 1
    CODE BS5950
    CHECK CODE MEMB 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 -
    143 148 153 157
    PARAMETER 2
    CODE BS5950
    PARAMETER 3
    CODE BS5950
    DFF 0 MEMB 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 143 148 -
    153 157
    MAIN 1 MEMB 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 143 -
    148 153 157
    RATIO 1 MEMB 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 143 -
    148 153 157
    SBLT 0 MEMB 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 143 -
    148 153 157
    SGR 0 MEMB 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 133 138 143 148 -
    153 157
    PRINT SUPPORT REACTION LIST 1 TO 9 20 22 32 TO 40
    PRINT MEMBER STRESSES LIST 3 64 68 73 78 83 88 93 98 103 108 113 118 123 128 -
    133 138 143 148 153 157
    FINISH
    looking forward to your answer.
    regards,
  • Your editor file is not having node no.50 51 52 and 53. Plate no 4 in the model is attached to some other nodes. Whether the warning that you spoke to pertains to this model or some other model.
  • You need to subdivide the plates further. Currently, the length of the longest side to the shortest side of each element is 5/0.17 = approx. 29.5
    A value greater than 8 triggers the warning message.
  • it's solved, thank you so much.
    best regards,
Reply Children
