Building Design regarding the Master/Slave Node
A question to be clarified:
for the building desing, normally, the plate will be used and divided/inclosed by beams, when the specificatoin of master/slave shall be used? and when we consider the drift or others result, what 's the difference  from view of analysis, between two cases (specifying the master/slave and not).
thanks in advance.
regards,
Parents Reply Children
