I have a steel structure Modeled, Analysed & Designed in STAAD.Pro V8i SS4 and Connections designed in RAM Connection plugin for STAAD. However, when I'm creating a repository for exporting the data to Pro Steel for detailing, RAM Connection data is not captured by ISM or structlink.
Is there any tool or option for that ? If not, do we have a work around, as this can be useful for the Steel Structural Design/fabrication Community.
Ram Connection v9.0 is in the final stages of testing. This version works with RAM SS 14.06.01.00 (launched directly from Ram Manager) and will export base plate and gusset plate geometry to the ISM repository. Integration with STAAD.pro is further off.
That could be useful. Any other teasers of new features? Release date?
Hi Jason, RAM Connection version 9.0 is now available for download on the SELECT Services download page.
SWEET! Just downloaded it. Y'all must've just done that, because I've been checking every morning since I saw version 9 show up in the service ticket dropdown box because I knew it would be soon. Thanks!
