Just a question in using the seismic definition in staad, i created a simple structure and an error occurs when i run analysis...
i only used perform analysis not p-delta
48. MEMBER WEIGHT
*** ERROR *** ABOVE LINE CONTAINS ERRONEOUS DATA.STAAD SPACESTART JOB INFORMATIONENGINEER DATE 27-Nov-12END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 5 0 0; 3 10 0 0; 4 0 0 5; 5 5 0 5; 6 10 0 5; 7 0 0 10; 8 5 0 10;9 10 0 10; 10 0 3 0; 11 5 3 0; 12 10 3 0; 13 0 3 5; 14 5 3 5; 15 10 3 5;16 0 3 10; 17 5 3 10; 18 10 3 10; 19 0 6 0; 20 5 6 0; 21 10 6 0; 22 0 6 5;23 5 6 5; 24 10 6 5; 25 0 6 10; 26 5 6 10; 27 10 6 10;MEMBER INCIDENCES1 1 10; 2 10 19; 3 4 13; 4 13 22; 5 7 16; 6 16 25; 7 2 11; 8 11 20; 9 3 12;10 12 21; 11 5 14; 12 14 23; 13 6 15; 14 15 24; 15 8 17; 16 17 26; 17 9 18;18 18 27; 19 10 13; 20 10 11; 21 11 12; 22 12 15; 23 15 18; 24 13 16; 25 16 17;26 17 18; 27 13 14; 28 14 15; 29 19 20; 30 20 21; 31 21 24; 32 24 27; 33 19 22;34 22 25; 35 25 26; 36 26 27; 37 22 23; 38 23 24; 39 20 23; 40 23 26;ELEMENT INCIDENCES SHELL41 10 13 14 11; 42 11 14 15 12; 43 13 16 17 14; 44 14 17 18 15; 45 19 22 23 20;46 20 23 24 21; 47 22 25 26 23; 48 23 26 27 24;ELEMENT PROPERTY41 TO 48 THICKNESS 0.1DEFINE MATERIAL STARTISOTROPIC CONCRETEE 2.17185e+007POISSON 0.17DENSITY 23.5616ALPHA 1e-005DAMP 0.05END DEFINE MATERIALMEMBER PROPERTY AMERICAN1 TO 18 PRIS YD 0.3 ZD 0.319 TO 40 PRIS YD 0.4 ZD 0.2CONSTANTSMATERIAL CONCRETE ALLSUPPORTS1 TO 9 FIXEDDEFINE WIND LOADTYPE 1INT 0.7 0.9 HEIG 3 6TYPE 2INT 1.2 1.6 HEIG 3 6DEFINE UBC ACCIDENTAL LOADZONE 0.4 I 0.85 RWX 8.5 RWZ 8.5 STYP 3 NA 1.2 NV 1.4SELFWEIGHT 1 FLOOR WEIGHTYRANGE 3 6 FLOAD 2.4 XRANGE 0 10 ZRANGE 0 10MEMBER WEIGHT19 TO 26 29 TO 36 UNI 2.3LOAD 1 LOADTYPE None TITLE EXUBC LOAD XLOAD 2 LOADTYPE None TITLE EZUBC LOAD ZLOAD 3 LOADTYPE None TITLE WXWIND LOAD X 1 TYPE 1 YR 3 6 ZR 0 10WIND LOAD -X 1 TYPE 1 YR 3 6 ZR 0 10LOAD 4 LOADTYPE None TITLE WZWIND LOAD Z 1 TYPE 1 XR 0 10 YR 3 6WIND LOAD -Z 1 TYPE 1 XR 0 10 YR 3 6LOAD 5 LOADTYPE None TITLE DEADSELFWEIGHT Y -1 FLOOR LOADYRANGE 3 6 FLOAD 2.4 XRANGE 0 10 ZRANGE 0 10 GYMEMBER LOAD19 TO 26 29 TO 36 UNI GY -2.3LOAD 6 LOADTYPE None TITLE LIVEFLOOR LOADYRANGE 3 6 FLOAD -1.9 XRANGE 0 10 ZRANGE 0 10 GYLOAD COMB 7 COMBINATION LOAD CASE 75 1.2 6 1.6 LOAD COMB 8 COMBINATION LOAD CASE 85 1.2 3 0.8 LOAD COMB 9 COMBINATION LOAD CASE 94 0.8 5 1.2 LOAD COMB 10 COMBINATION LOAD CASE 105 0.9 1 1.0 LOAD COMB 11 COMBINATION LOAD CASE 111 1.0 5 0.9 PERFORM ANALYSISSTART CONCRETE DESIGNCODE ACIFC 27600 ALLFYMAIN 276000 ALLFYSEC 276000 ALLMINMAIN 20 ALLMINSEC 10 ALLTRACK 0 ALLDESIGN BEAM 23 26 32 36DESIGN COLUMN 11 12 17 18CONCRETE TAKEEND CONCRETE DESIGNPRINT SUPPORT REACTION ALLFINISH
Try the below code. I have corrected your code:
STAAD SPACE
END JOB INFORMATION
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
MEMBER INCIDENCES
ELEMENT PROPERTY
ISOTROPIC CONCRETE
E 2.17185e+007
POISSON 0.17
DENSITY 23.5616
ALPHA 1e-005
DAMP 0.05
END DEFINE MATERIAL
CONSTANTS
SUPPORTS
1 TO 9 FIXED
DEFINE WIND LOAD
TYPE 1
TYPE 2
SELFWEIGHT 1
MEMBER WEIGHT
FLOOR WEIGHT
UBC LOAD X
PERFORM ANALYSIS
CHANGE
UBC LOAD Z
SELFWEIGHT Y -1
FLOOR LOAD
MEMBER LOAD
5 1.2 6 1.6
5 1.2 3 0.8
4 0.8 5 1.2
5 0.9 1 1.0
1 1.0 5 0.9
CODE ACI
FC 27600 ALL
FYMAIN 276000 ALL
FYSEC 276000 ALL
MINMAIN 20 ALL
MINSEC 10 ALL
TRACK 0 ALL
CONCRETE TAKE
END CONCRETE DESIGN
FINISH
-Vivek
