When I'm trying to export connection details from RAM Connection V8i to Pro Structures using the "export" tool , getting an error - Connectionexport.dll not registered.What can be the possible cause and solution for the same?
This is a very old interface and option that we no longer use (I though it was removed from the menus). Going forward, the ISM interface will be the means of transferring connection specific information from Ram Connection to other applications, including ProStructures. For now, this is limited to plates and connection tags and only works for Ram Connection within Ram Elements, but other items and other applications will come into the ix in 2013.
Ok. We can still see that <tab>. Thanks for the reply Seth.
