Base Pressure Calculation
Is there any technical reference how the base pressure in staadpro or staad foundation is calculated? This is in relation to my observation that the base pressure seems to be a function of the  thickness of the mat (plate). The thicker the plate you assign the lower the base pressure becomes this is even under constant uniform pressure load and neglecting self weight of mat.
My understanding is that the base pressure is a function of the soil spring stiffness which is also a function of the influence area and the total load which is this case both are constant since self weight  of the plate is neglected.
Can anybody from the support shed some light on the matter.
