Inclined Load Path due to Member Offset at one Node
Dear Staad Experts,
Attached is a simple Joist with tapered ends. For making the model as close to the real application as possible I have applied a "OFFSET" so as to achieve the top flange straight, due to this the NA has become slanting for the TAPERED section of the beam.
Since the "LOAD applied is at the neutral axis, this results in a Axial force.
Is there any way that I can make staad apply the loading at the top flange location of the beam so that the Load line is straight ??
Please help
JOIST.std
Parents Reply Children
