I am a relatively new user to RAM SS concrete.
I am trying to add a column which sits on a cantilever. RAM SS will not let me do this. There must be some way, any suggestions are appreciated.
Remember to add the column to the storey above the level with the cantilever. Please advise me if this resolves your query.
Answer Verified By: B.Greger
And use Options - Reference Layout Types and/or construction grids to help with alignment. If you accidentally place the column slightly off the beam line, the data check should let you know that.
