hi
I am new at using the program staad.offshoreHow could they use as general coordinates in staad.offshore?
If you are asking how to create the model in STAAD.offshore by entering joint coordinates, the answer is that STAAD.Offshore is a load generator program which generates loading on a STAAD.Pro model. So STAAD.Pro should be used to create the model and then from within the STAAD.Offshore program, you can open the STAAD.Pro model through the menu option Structure > Select STAAD.Pro Model.
thanks for responding.
I already did it.
The problem is how to use the box axes origins, as it indicates a specific coordinate for the mudline and wave origin
I would add to jorge question should define the origin in staad model before moving to staad.offshore as loads vary with respect to the point of origin set out in staad, but are not sure how to set this reference to the safety of the loads generated by the staad.offshore are correct.
Thanks.
-Morgan-
