[STAAD PRO] Ask : API code design parameter
Gents,
today i'm working on pipe/tubular section in my model. to check the ratio in analysis, i'm using API code, but for non tubular section, i use AISC 9th Ed.
however, i have some question regarding API code. (i use STAAD Pro v8i SELECT 4 20.07.09.31)
in API design parameter :
1.  BEAM command
BEAM
1.0
Beam parameter:
0.0 = design only for end moments or those at locations specified by the SECTION command.
1.0 = calculate moments at twelfth points along the beam, and use the maximum Mz location for design.
2.0 = Same for BEAM 1.0, but additional check is made at each end.
when i use BEAM 2.0 ALL -> it shows ERROR.
PARAMETER 6
CODE API
BEAM 2 ALL
RATIO 1.33 ALL
LOAD LIST 4
CHECK CODE ALL
FINISH
why it says ERROR ?
if i use BEAM 1.0 ALL,  what's the different between BEAM 1.0 in AISC 9th Ed ?
2. MAIN Command
MAIN
0.0
Design for slenderness.
1.0 = Main member
2.0 = Secondary member
could you explain to me what is main and secondary member means ? In API RP 2A-WSD code they say secondary member is stair/ladder , boatways, etc.
otherwise will be as primary member.
but i'm not really sure if this is the same just like STAAD do.
your explanation is highly appreciated.
Thank You all.
Parents Reply Children
