User is getting an error " The application has failed to start because xmllite.dll not found. Re-installing the application may fix this problem" while opening the STAAD Pro.
Save this file in C:\WINDOWS\System32 folder. If there is already a file by the same name, it would ask you to replace the same. You need to replace it.
Hello friends, I'm facing same error in my system that is missing xmllite.dll files, Thank god i got a webpage which provides all the missing dll file within minute you just need to follow the instruction and fix these error.
Hope this will help!!!
